Vacuum Tube SPICE Models
Old 25th February 2016, 09:31 AM   #1101
ballpencil is offline ballpencil  Indonesia
Pardon my ignorance but how do we get the LTSpice code from the Weaver model above?
Old 25th February 2016, 12:35 PM   #1102
jackinnj is offline jackinnj  United States
jackinnj's Avatar
See post 1090 -- the LTSpice syntax is a bit different from MSIM -- you need curly brackets.
I used these parameters:
KG1=0.00230261 kp1=-6.471 kp2=31.77 kp3=-5.93e-6 kp4=0.1736 kt1=50 kt2=0.08 kc1=6.721e-4 kc2=7.588e-2 kc3=1.708 ks1=3.462e-6 ks2=3.451e-4 ks3=-1.169e-2 kcs=0.09196 ecref=0 esref=250
I don't have any screen current data for the tube.
Old 26th February 2016, 06:06 AM   #1103
karsten21 is offline karsten21  Germany
Default 6F1P Spice Model
Hello,
Using utracer from Ronald and extractModel from Derk Reefman I was able to create two models for the russian 6F1P tube.
Itīs a small signal Pentode which include also a Triode.
Have fun!
Best regards
Karsten
/// Never forget your towel \\\
You who are doomed, enter and abandon yourself to despair!
Old 2nd March 2016, 04:53 PM   #1104
jackinnj's Avatar
Rethinking this -- specify IG2 as a function of Vak/Vg2 and Vg1. A little less "phenomenological"
I could use more data for Vg1→ 0
Old 3rd March 2016, 08:47 PM   #1105
jim86174 is offline jim86174  United States
I am looking for a quality schematic using 2 6l6 pp.with 2 12ax7 drivers. Any help would make me very happy.
Old 8th March 2016, 10:53 PM   #1106
famousmockingbird is offline famousmockingbird  United States
Hey Gang, does anyone have a 6N7 model they would like to post for me?
I have been using one section of an ECC33 in LTSpice to model the two sections of a 6N7 in parallel, it's the closest thing I have but I would like a real model of a 6N7 before I rip my amp apart.
I want to thank Thomas from Vinylsavor blog for giving me the idea of trying a 6N7 to drive my 6HJ5 amp. I plan to current source the plate @10mA and use a blue LED on the cathode.
Thanks,
-bird
Old 9th March 2016, 02:19 AM   #1107
needtubes is offline needtubes  United States
I found the model below among my models, but cannot guarantee accuracy.
Code:
.SUBCKT TRIODE_6N7 1 2 3 ; Plate Grid Cathode
+ PARAMS: CCG=3.6P  CGP=2.6P CCP=4.6P RGI=2000
+ MU=37 KG1=1680 KP=340 KVB=396 VCT=3.906E-5 EX=1.32
E1 7 0 VALUE={V(1,3)/KP*LOG(1+EXP(KP*(1/MU+(VCT+V(2,3))/SQRT(KVB+V(1,3)*V(1,3)))))}
RE1 7 0 1G  ; TO AVOID FLOATING NODES
G1 1 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1}
RCP 1 3 1G   ; TO AVOID FLOATING NODES
C1 2 3 {CCG} ; CATHODE-GRID
C2 2 1 {CGP} ; GRID=PLATE
C3 1 3 {CCP} ; CATHODE-PLATE
D3 5 3 DX ; POSITIVE GRID CURRENT
R1 2 5 {RGI} ; POSITIVE GRID CURRENT
.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N)
.ENDS
Old 9th March 2016, 03:00 PM   #1108
Thank you needtubes, i will run it in LTSpice and see how it works out.
Old 9th March 2016, 05:52 PM   #1109
jazbo8 is offline jazbo8
jazbo8's Avatar
Is it accurate enough? You be the judge...
The above 6N7 SPICE model vs. the GE datasheet:
Old 9th March 2016, 06:16 PM   #1110
Looks accurate enough to me but I can't seem to get it to work in LTSpice correctly. I mean I don't get any errors but I am getting weird readings like the same voltage at the cathode is appearing on the grid in a simple common cathode gain stage. The model looks different then the ones I am use to so maybe I need to change something in the txt file?
Vacuum Tube SPICE ModelsHide this!Advertise here!
Vacuum tubes SPICE models, another way Dominique_free Software Tools 2 12th November 2013 06:26 PM
Tube spice models nhuwar Tubes / Valves 45 25th November 2011 08:47 AM
Computer program for tube curves and Spice models Jim Tonne Software Tools 9 21st November 2010 10:10 AM
Got my tube spice models, and tubed CD player page back on the air wa2ise Tubes / Valves 2 20th April 2008 11:07 PM
