Vacuum Tube SPICE Models
Old 20th November 2015, 10:22 AM   #1031
artosalo is offline artosalo  Finland
artosalo's Avatar
Does anyone know the g1-plate capacitance of triode connected EL34 ?
Old 20th November 2015, 10:28 AM   #1032
jazbo8 is offline jazbo8
jazbo8's Avatar
According to the Ayumi EL34T model, 7.2pF.
Old 20th November 2015, 11:16 AM   #1033
artosalo's Avatar
Thanks again.
Now, excluding Cg1-a+Miller effect, I assume that the Cin (=mainly Cg1-k) is 15.5 pF as is specified as pentode.
Old 20th November 2015, 11:22 AM   #1034
jazbo8's Avatar
I don't know if Ayumi actually measured them or got the figures from somewhere, but here are the capacitances used in his EL34T model:
CGA G A 7.2p
CGK G K 9.1p
CAK A K 8.4p
Old 20th November 2015, 11:28 AM   #1035
artosalo's Avatar
The origin of this subject is that I have claimed that an ECC83 as a common cathode stage is capable of "drive" triode connected EL34 SE.
My earlier LTSpice simulations show that this is fully OK, but quite common opinion is that it is not.
Maybe I have to take the soldering iron...
Old 20th November 2015, 05:57 PM   #1036
Ufudu is offline Ufudu  South Africa
Ufudu's Avatar
Default Optimising Spice model parameters
I was asked by Bondini to measure a few 5CZ5 pentodes on the uTracer which I duly did. I then extracted the Spice model using Derk Reedman's extractmodel for the beam pentode using DERKE. One set of triode connected curves and 4 sets of pentode curves for different values of Vs were used. The visual correlation between simulated and measured data looked pretty good.
I then built a simple Spice circuit that simulates what the uTracer does in UL mode, and measured the same on the uTracer. The comparison is shown in the attached file, with the solid blue lines being the Spice curves and the other coloured curves being the measured ones.
You can see some deviation in the area of interest, which is probably due to the inclusion of too many low current data points in the optimisation.
Any views on this?
Old 21st November 2015, 04:12 PM   #1037
famousmockingbird is offline famousmockingbird  United States
I searched this thread for a model on the 50EH5 and had no luck. If someone out there has one or can make one that would be bananas.
http://frank.pocnet.net/sheets/093/5/50EH5.pdf
Old 21st November 2015, 04:15 PM   #1038
dgta is offline dgta  United States
I would like a model for the 6AC7 if anyone has one. Many thanks.
Old 21st November 2015, 04:48 PM   #1039
Actually I wouldn't mind learning how to do this myself, does anyone also have a link to making a spice model from datasheets/plate curves?
Old 21st November 2015, 05:45 PM   #1040
Ufudu's Avatar
Default 6CA7
@dgta,
EH 6CA7 attached. If you PM me with your address I can mail you the file.
Vacuum Tube SPICE ModelsHide this!Advertise here!
Tube spice models nhuwar Tubes / Valves 45 25th November 2011 09:47 AM
Computer program for tube curves and Spice models Jim Tonne Software Tools 9 21st November 2010 11:10 AM
Spice models stinius Solid State 0 18th November 2008 10:07 PM
Got my tube spice models, and tubed CD player page back on the air wa2ise Tubes / Valves 2 21st April 2008 12:07 AM
