Vacuum Tube SPICE Models
Old 10th November 2015, 03:43 PM   #1021
dgta is offline dgta  United States
Originally Posted by jazbo8 View Post
I deleted it the Ayumi model because it was not good enough, try the one jackinnj generated.
I don't see one. I see the graphs where he's done some work generating parameters, but I don't see an actual model posted and I'm not knowledgeable enough to put one together from that.
Jackinnj, if you read this, can you please post the model? Thanks.
Old 10th November 2015, 04:53 PM   #1022
jazbo8 is offline jazbo8
jazbo8's Avatar
Originally Posted by dgta View Post
I don't see one.
Sorry, I could not help you since I don't use the Rydel model, perhaps you can PM Jack to get the model from him.
Old 10th November 2015, 05:09 PM   #1023
artosalo is offline artosalo  Finland
artosalo's Avatar
I don't know if that's the most recent version, but E182CC is in there.
Thanks, but this model does not work, or at least I can't get it to work.
Old 10th November 2015, 05:37 PM   #1024
RajkoM is offline RajkoM  Bosnia and Herzegovina
RajkoM's Avatar
This Ayumi model works.
BTW, E182CC (Mullard or Philips) sounds much better in practice than the simulation shows, IMO
* Generic triode model: E182CC
* Copyright 2003--2008 by Ayumi Nakabayashi, All rights reserved.
* Version 3.10, Generated on Sat Mar 8 22:42:34 2008
* Plate
* | Grid
* | | Cathode
.SUBCKT E182CC A G K
BGG GG 0 V=V(G,K)+0.56912497
BM1 M1 0 V=(0.020096637*(URAMP(V(A,K))+1e-10))**-0.83371956
BM2 M2 0 V=(0.64275075*(URAMP(V(GG)+URAMP(V(A,K))/17.776569)+1e-10))**2.3337196
BP P 0 V=0.0068220515*(URAMP(V(GG)+URAMP(V(A,K))/27.657018)+1e-10)**1.5
BIK IK 0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.0041807778*V(M1)*V(M2)
BIG IG 0 V=0.0034110257*URAMP(V(G,K))**1.5*(URAMP(V(G,K))/(URAMP(V(A,K))+URAMP(V(G,K)))*1.2+0.4)
BIAK A K I=URAMP(V(IK,IG)-URAMP(V(IK,IG)-(0.0037843497*URAMP(V(A,K))**1.5)))+1e-10*V(A,K)
BIGK G K I=V(IG)
* CAPS
CGA G A 4.1p
CGK G K 6p
CAK A K 1.1p
.ENDS
Old 10th November 2015, 05:41 PM   #1025
artosalo's Avatar
Thanks RajkoM. This works.
Old 10th November 2015, 05:44 PM   #1026
Newbie question: Looking at an FFT plot, the fundamental (1khz in pic below) shows not as a sharp spike but sort of a wider shape with a peak at some +20dB. Is this just a LTspice inaccuracy, is it the result of less than optimal tube models, or ??? I get this behavior with a variety of tubes.
And does this indicate that all other peaks (f2, f3, etc) are similarly off?
Old 10th November 2015, 05:50 PM   #1027
jazbo8's Avatar
It has nothing to do with the tube models, it seems the window function in LTSpice isn't set up properly, BTW, in the future, please post LTSpice related questions to this thread.
Old 10th November 2015, 06:09 PM   #1028
Thank you, I will. I posted here thinking there may be an issue with the models.
Old 10th November 2015, 06:17 PM   #1029
Mooly's Avatar
Have a look at post #19 in the LT thread jazbo linked to
Old 10th November 2015, 07:14 PM   #1030
cogsncogs is offline cogsncogs  United States
cogsncogs's Avatar
Now the LTSpice model of E182CC would be needed.
Does anybody have ?
Yes... Included in a zip file I posted a few months ago in this thread.
Code:
* E182CC_LC LTSpice model
* Modified Koren model (8 parameters): mean fit error 0.170981mA
* Traced by Wayne Clay on 10/18/2013 using Curve Captor v0.9.1
* from Philips data sheet low current (0-10mA) plate curves
.subckt E182CC  P G K
    Bp  P K  I=
+ (0.2203535708m)*uramp(V(P,K)*ln(1.0+(-0.1063849781)+exp((3.874792069)+
+ (3.874792069)*((27.50585286)+(-67.76184167m)*V(G,K))*V(G,K)/sqrt((10.80206098)**2+
+ (V(P,K)-(-7.968864547))**2)))/(3.874792069))**(1.172598079)
  Cgk G K 4.7p ; 0.7p added
  Cpk P K 1.6p ; 0.5p added
  Cgp G P 1.8p ; 0.7p added
  Rpk P K 1G ; to avoid floating nodes
  d3  G K dx1
.model dx1 d(is=1n rs=2k cjo=1pf N=1.5 tt=1n)
.ends E182CC
Vacuum Tube SPICE ModelsHide this!Advertise here!
Tube spice models nhuwar Tubes / Valves 45 25th November 2011 08:47 AM
Computer program for tube curves and Spice models Jim Tonne Software Tools 9 21st November 2010 10:10 AM
Spice models stinius Solid State 0 18th November 2008 09:07 PM
Got my tube spice models, and tubed CD player page back on the air wa2ise Tubes / Valves 2 20th April 2008 11:07 PM
