Long story short: 813 SE monoblocks, 900V 110mA B+, hybrid Graetz bridge rectifier, capacitor input filter, what tube to choose: 1 x 5R4 or 2 x 6AU4GTA (damper diodes) per channel??
The low prize, indirect heating and long warmup time of the 6AU4´s seems attractive, but will they survive??
I know a lot of people use them as rectifiers in power amps, but 900V and 110mA is not an easy task for a tube rectifier.
According to the RCA datasheet they ought to survive, you're still way below their maximum capability.
Go for the steatite ones.
Now I only have to find locally available octal sockets that can handle the voltage.
The 6AU4GTA's in a hybrid Graetz bridge should work good.
I have been running a similar power supply for my active loaded 300B amplifier for 2 years now without any problems. The supply for the active loaded 300B uses a pair of 6AX4GTB's in a hybrid Graetz bridge configuration with a 15uf-10Hy-15uf capacitor input filter. The output is 1000 volts at 140ma. The peak and avarage current specs for the 6AX4GTB is just slightly lower than the 6AU4GTA's.
You can use PSUDII from the Duncan amps page to verify that you are keeping the peak current into the first cap below the 1.1 amp peak limit of the 6AU4GTB.
As for why they recommend that you don't use them for power rectifiers I have no clue... They do a great job in the application.
Gary
Gary
Damper Diodes
I use a 6CG3 12 pin compactron damper diode as a "slow turn on" for a pair of 866jr's. It's running 825v at around 150ma - works very nicely. I've had it running this way for almost a year now, with regular use.
I'd bet you won't have any trouble with the 6AU4GTA, but some of the later compactron damper diodes have higher ratings.
- Gary
http://www.the-planet.org
- Gary
I doubt it, that relates to the pulse/scan ratio cycles.
BTW, the RCA datasheet doesn't mention any restrictions on the use as a power rectifier.
In RCA I trust....
could that have something to do with the "Operation as power rectifier is not recommended"????
In RCA I trust....
Fuling said:Damn it, I just read the last words in the GE datasheet:
(same thing in the Sylvania sheet)
"Operation of this tube as a power rectifier is not recommended"
There is no further explanation why it isn´t recommended?!?
I think is has a lot to do with warranties, tech. support etc. The tubes were developed for use as damper tubes and they were only tested in that application. Why would you use damper tubes when plenty of power rectifier tubes were available (back then)?
A few of the damper tubes are actually shown with ratings for both uses. Take a look at the Sylvania datasheet for the 6BY5GA. I use that tube in my 2A3 SE amp - works great.
Best regards,
Mikkel C. Simonsen
Gary P said:For the current waveforms you should be able to model the PS as a full wave CT with double the voltage on the transformer.
For voltage output I have been modeling both SS and Vacuum rectifiers and splitting the difference in voltage.
Gary
just curious, as I'm playing around with this now.... for the voltage output interpolation, are you modeling first as "solid state bridge" and then "VT bridge", or "full wave SS" and then "full wave VT"?
Also, for the current waveforms, are you using the "full wave SS" or the "full wave VT"?
Just curious, is there a better way to do this these days?
Thanks all!
Re: Damper Diodes
Hi Gary,
I want to use a pair of 866A full-wave rectified to provide 700V, 200ma power supply for my power amp. project.
Can I use a 6CG3 to connect between the ground and the centre tap of the transformer as a slow turn on? If yes, should the plate of 6CG3 be connected to ground and its grid to the ct of transformer?
Would it be better to short it out of the circuit after all are turned on?
Thank you for any advice and information.
Best Regards,
T.C. MA
The-Planet said:I use a 6CG3 12 pin compactron damper diode as a "slow turn on" for a pair of 866jr's. It's running 825v at around 150ma - works very nicely. I've had it running this way for almost a year now, with regular use.
- Gary
Hi Gary,
Best Regards,
T.C. MA
- Tubes / Valves
- 6AU4GTA as High voltage rectifier
