Joined 2009
Usually the transformer is used in conjunction with a resistor which does the actual I/V conversion.. Have a look at my old thread here:
http://www.diyaudio.com/forums/tube...r-i-v-converter-differential-current-dac.html
The Simple Transformer Explanation… | H i F i D U I N O
this is something I have found today. This is a kind of answer I would like to hear.
Kevin, I'm going to read your thread now.
Not trying to replace Kevin, but R1 seems to be necessary to damp tranformer resonances in higher frequencies,or compensate for rising frequency responce, or both.
Interstage transformers -especially step-up ones- are a bit sencitive in this. Secondary must be always loaded.
C2 is a power supply filter capacitor.
Yes, I figured it out about r1, c2 was strange to me because the source is virtual, ie you don't see the diodes,filters etc.
I still think that resistors is not a good idea for i/v duties. It is quite simple though.
The thing is the "ground" of a differential stage, especially for a dac is a digital dumpster. Everything there is unwanted. So I don't want to couple this dumpster with such a clean signal as a differential.
- Tubes / Valves
- D3a preamp.
