diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   where can I buy fully assembled tube amplifiers here in the U.S (http://www.diyaudio.com/forums/tubes-valves/24356-where-can-i-buy-fully-assembled-tube-amplifiers-here-u-s.html)
scientist1 17th December 2003 05:10 AM
Whats going on guys. i am about to purchase a pair of Ellis Audio 1801b's. I am no scienist..so building a tube amp is not an option. I am looking to spend under $2k for the tube amps. The amps will be used on a regular basis ( homeaudio & Hometheater use). I am looking for a good amp to push the Ellis Speakers. Also are Tube amps reliable??? when compared to a solid state amp???
I like my music relatively loud.....I am not totally sold on tube amps...I see tube amps rated @15Watts per channel...i'm like what the &%$#@#@...Is this enough power to drive my speakers loud enough with some sort of clarity....
But anyways..i do not want to bore you guys...just recommend some online sites that sell Good quality tube amps in the United States.
Thanks.
Brett 17th December 2003 09:03 AM
Re: where can I buy fully assembled tube amplifiers here in the U.S
I looked up your speakers. At 84/85 dB/1W/1m you're either going to need a lot of power, listen softly, or use them as headphones.
Depends on the design and how well it's built. But usually, yes.
Horses for courses. Your speakers are 85dB/W which is very inefficient, and mine are around 106dB (or 100x more efficient than yours), so 15W is too much, even VERY loud in my large room. For you, I suspect it won't be even close to enough.
I'd suggest you buy a big hog SS amp like a Bryston.
$US2k isn't going to get you anything decent new in a high power, ie >50W tube amp.
Try Audiogon
Magnetmaz 17th December 2003 12:59 PM
or, if you must have tube amps, sell your speakers on ebay and get something more efficient.
I dropped my B&W's that were 89db/w/m for some Klipsch that were 98db/w/m and i never got my 8 watt per channel tube amp up above 3 on the volume knob. I probably could have gotten away with a 2 watt / channel tube amp.
-Maz
Copyright 1999-2017 diyAudio
