Correct wiring types
Old 27th September 2013, 05:07 PM   #11
Funker is offline Funker  Germany
Default Wiring example
Hi folks,
here an example of some kinds of wiring I done with ordinary switchgear wire.
The first both pics showing the input panel and the line driver of my homebrew pre-amp. The third pic show the harness of the line driver stage. The both right ones are showing the wiring in my MC-3500 power amp clones.
73
Wolfgang
Ground your devices before they ground you
Old 27th September 2013, 05:29 PM   #12
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
Absolutely beautiful work, Funker. Truly professional.
Frank
Old 28th September 2013, 04:00 PM   #13
hschaser is offline hschaser  Singapore
hschaser's Avatar
WOW.. fantastic and neat work...
Old 28th September 2013, 04:44 PM   #14
DF96 is offline DF96  England
Such neat wiring can be a pig to debug/fault-trace, and can encourage coupling between different circuits. I do my best to avoid it!
Old 28th September 2013, 08:50 PM   #15
Hi DF96,
yes it could, but I spent lot of effort to avoid it , because I personally like this way of wiring. My invested time to finish such kind of equipment is not an issue. I made drawings of the wiring and give all wires a running number. In case of a fault its easy to trace each single wire vom its start its destiny. In several projects I had to make one or the other cable harness twice, because of a false running wire. But most of these bundles contains only supply , ground, heater , control or balanced audio wires.
I never put high impedeance wires into my cable looms. For other sensitive wires with lower impedance I take screened ones . In the added pics of my previous page there are lot of balanced circuits, which will not an issue for coupling high frequency loss.
I worked in a company way back in the seventies. This Firm produced equipment for german brodcasting and the post office telecom in small quantities. We did the wiring in the same way, without any troble at all.
Here are another sample of how I made it. You see that the plate wires run separate from the harness (the black sleeve left of the valve sockets), the heater wires are screened avoid spreading mains hum into the circuit. These pics showing the interior of a 10W Guitar amp I build a while ago.
73
Wolfgang
Old 28th September 2013, 09:10 PM   #16
On Hiatus
SY's Avatar
That's quite reminiscent of the old Quad and Leak stuff- I seethe with jealousy.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 30th September 2013, 02:19 AM   #17
hschaser's Avatar
This is real pro in action. neat , organised and structured. The German way. My hats off to you Funker. Wish I can do the same in the future. Still in progress of rewiring my simple tube pre amp.
Old 30th September 2013, 03:18 AM   #18
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
another source of wires....crt video cables...the coax cable is tops and the small gauge wires are good to use....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 2nd November 2013, 06:56 AM   #19
hschaser's Avatar
Hi all,
I will really appreciates your input as I this is my first attempt on the simple pre-amp.
in the diagram below
https://dl.dropboxusercontent.com/u/...ips%20Caps.jpg
Thanks in advance for all your great inputs!!!
Old 2nd November 2013, 02:20 PM   #20
wicked1 is offline wicked1  United States
wicked1's Avatar
That's a lot of unsoldering and changes. Probably better to scrap the PCB and build point to point.
Correct wiring typesHide this!Advertise here!
correct heater wiring gja Tubes / Valves 11 7th November 2010 12:08 AM
Help finding correct amp plus wiring dilema. gixxierific Car Audio 7 15th November 2008 01:01 PM
I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) Audiophilenoob Chip Amps 9 16th August 2005 04:37 AM
This crossover wiring correct? Rufes1 Multi-Way 6 5th February 2004 03:46 AM
Correct PSU Wiring Rarkov Parts 6 10th October 2002 08:11 PM
