SE GU-50/6CB6 Pentode Design
Old 21st September 2013, 09:22 PM   #1
ryuji is offline ryuji  United States
Default SE GU-50/6CB6 Pentode Design
Ripped up my old 5 channel 807/6cb6 based amplifier because I need to rebuild into a new rack mountable chassis. Decided to go with a completely new design.
Still havent ordered any parts yet. PSU design was inspired by Peter Millett's DCPP.
This will still be 5 channels just like the old one. About 40 mA per GU-50, probably around 8 mA per 6CB6 to match old amp. Of course ill be playing with bias as i made it adjustable
Just wanted some potential commentary before i ordered the psu parts.
Ill be using different mosfets and of course better choice/fewer zeners to get the required voltage. i ran with the stock parts in the program
Old 21st September 2013, 09:27 PM   #2
davorin is offline davorin  Croatia
GU50 screen need more voltage, better 300V than 150V!
Old 21st September 2013, 09:33 PM   #3
Hmm, worth a try. But i have doubts that -48v is enough to keep the anode current down. might need to order another/series two 48v supplies together.
Im guessing 300v would be sought after to obtain a flatter curve?
just realized i typo'd out the intended plate current for gu-50's (40 mA)
Old 22nd September 2013, 07:58 PM   #4
Found a cheap single module dc-dc converter at digikey that offers -72v. I think that should be plenty of negative to run 300v screen on the gu-50. Runs off 12v too
Old 8th October 2013, 11:34 AM   #5
heres the fully assembled and tested psu board:
12.6v DC and 400v AC input,
500v 300v,150v DC output, no current limit or constraints. full regulation even at open circuit.
6.3v 3A output for operating the small signal pentodes
5x -0v-72v bias pots
5x -0v-5v bias pots
bias supply powered by this guy:
http://www.murata-ps.com/data/power/ncl/kdc_nmt.pdf
Old 29th October 2013, 05:05 PM   #6
807tubenut is offline 807tubenut  United States
807tubenut's Avatar
Very nice my friend, any updates?
All my battles have been won, But the war has just begun.
Old 29th October 2013, 06:04 PM   #7
I am just about done with the chassis wiring. all the major components are in place but its taking a bit of time to carefully solder to the tabs on the plug i chose for inputs/outputs. Slow progress as i have been distracted and busy with work lately and have been working on it in sessions. also need to resolve a issue i had with a resistor.
Old 30th October 2013, 02:05 AM   #8
807tubenut's Avatar
Move to resistors rated for 750+v in that problem area, R12?
Old 12th November 2013, 12:25 AM   #9
Amp is completed, but i need a new mosfet for main b+ ripple filter. the one i have there failed due to a failed zener diode
otherwise works exactly as intended. the fixed bias on the preamp works wonderfully.
i went with 500v and 6au6a's in the preamp positions
Old 13th November 2013, 05:45 AM   #10
for anyone that cares. this reflects current state of the design:
sorry for a little bit of messiness in diagram showing lowish voltage design
the lm338 is only running one of the 6AU6A's, the other 4 are running in pairs of two off the 12.6v supply. a bit more power efficient that way anyways.
SE GU-50/6CB6 Pentode DesignHide this!Advertise here!
Pentode curves for GU 50 SE amp with 700V B+ usbekhistan Tubes / Valves 18 20th January 2013 09:57 AM
500V SE pentode design doozerdave Tubes / Valves 13 23rd November 2012 03:37 PM
Simple SE GU-50 Einric Tubelab 49 3rd June 2012 10:13 AM
GU 50 monoblock gedd Tubes / Valves 8 21st October 2011 11:08 AM
GU-50 output trafo croccodillo Tubes / Valves 7 11th May 2007 09:55 AM
Copyright ©1999-2017 diyAudio
