Winter is coming... Time to start GM70 SE parafeed amp
Old 14th November 2013, 10:45 PM   #171
yagoolar is offline yagoolar  Poland
yagoolar's Avatar
Send a message via ICQ to yagoolar Winter is coming... Time to start GM70 SE parafeed amp
Kevin,
That would be helpful if you write you findings.
Old 15th November 2013, 12:30 AM   #172
kevinkr's Avatar
Unfortunately I blew up my uTracer last night by shorting out the grid bias supply, just waiting for replacement parts to arrive from Mouser. I will trace the 6ж52п once I have repaired the unit and post the curves here.
One of the four tubes currently in my possession has a racked internal structure so the alignment of electrodes is suspect, the rest seem OK mechanically speaking.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 16th November 2013, 05:23 PM   #173
yagoolar's Avatar
Default 6ж9п - Ia(Ug) @ Ua=Ug2=170V
Just measured this curve
Old 17th November 2013, 01:04 PM   #174
yagoolar's Avatar
Default 6ж52п - Ia(Ug) @ Ua=Ug2=170V
6ж52п triode strapped - measured
Old 17th November 2013, 02:15 PM   #175
mogliaa is offline mogliaa  United Kingdom
mogliaa's Avatar
Hi there,
I did these traces some time ago and didn't have 6z52p at hand unfortunately. I had 6z51p amongst other pentodes that I traced in triode mode....
http://www.bartola.co.uk/valves/2013...n-triode-mode/
Ale
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
Old 17th November 2013, 02:18 PM   #176
yagoolar's Avatar
Originally Posted by mogliaa View Post
Hi there,
Ale
I have seen them on your website. I can send you one or two to measure if you like.
Old 17th November 2013, 02:19 PM   #177
yagoolar's Avatar
Default 6ж52п - Ia(Ug) @ Ua=Ug2=170V & 143V
Old 17th November 2013, 02:25 PM   #178
mogliaa's Avatar
I think I have 2 or 4 of them, if you can wait till next weekend I may find some time to fire up the uTracer and trace them. Not sure if it would be a representative plot given variance reported but worth trying!
Ale
Old 17th November 2013, 03:34 PM   #179
yagoolar's Avatar
Combining results of yours and Kevin's on the same tool, I think the results will be good enough.
Old 17th November 2013, 05:19 PM   #180
yagoolar's Avatar
Default 6ж52п - Ia(Ua) @ Ug2=(-4.0;0.0)
More curves from my manual Lamp tester P-508.
Solid black is polynomial approximation
Data below (1st col. is Ua value)
Ua\Ug -4,0 -3,5 -3,0 -2,5 -2,0 -1,5 -1,0 -0,5 0,0
329 0,60 1,55 4,00 9,40 19,50 36,00 64,00
298 0,33 0,82 2,25 5,60 14,00 26,00 54,00
264 0,18 0,42 1,15 3,28 9,38 21,40 36,00 52,50
235 0,10 0,20 0,60 1,75 5,40 14,50 28,00 44,00 62,00
206 0,05 0,10 0,27 0,82 2,82 9,40 22,30 36,00 54,00
176 0,03 0,05 0,14 0,35 1,33 5,20 15,50 29,00 44,00
146 0,00 0,02 0,07 0,15 0,53 2,50 9,80 22,00 36,00
116 0,00 0,02 0,04 0,07 0,20 0,95 5,00 14,50 28,00
105 0,00 0,00 0,02 0,05 0,14 0,60 3,68 11,50 25,00
Winter is coming... Time to start GM70 SE parafeed ampHide this!Advertise here!
FINALLY I can start building my GM70 djn Tubes / Valves 60 21st January 2015 05:55 PM
GM70 SE Amplifier gabrielbecheanu Tubes / Valves 35 18th July 2011 04:01 AM
Well, it is time to start thinking about winter projects. GM70 djn Tubes / Valves 14 17th August 2010 08:49 AM
GM70/GM70 parafeed SET? louischia Tubes / Valves 10 4th December 2008 03:12 PM
Soft start & Dead time for TL494 ifrythings Power Supplies 9 18th May 2008 08:31 PM
