EL34 PP oscillating
EL34 PP oscillating
Old 20th September 2013, 11:57 AM   #1
luixssj3 is offline luixssj3  Italy
Default EL34 PP oscillating
Hi guys,
I build two twin amplifier with EL34 PP UL with 12AX7/2SK170 cascoded.
Here is the schematic https://picasaweb.google.com/luixssj...71677464979522
One amp is working correct, the other is oscillating in a strange way!
From the speaker I hear an intermittent hum like 50Hz and at the oscilloscope I found that there is a ca. 700kHz oscillation modulated by the line noise.
here is a photo of oscilloscope https://picasaweb.google.com/luixssj...72339580485506
I tried everything, rising feedback capacitor, moving cables, disconnect feedback, inverting anode tap and relative connections.... nothings seems to change!!! I'm getting crazy!
can anyone help me?
Last edited by luixssj3; 20th September 2013 at 12:09 PM. Reason: link not working
Old 20th September 2013, 12:00 PM   #2
I forget to mention that the amp is build on pcb and here are they:
Old 20th September 2013, 12:03 PM   #3
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
I cannot see your schematic or scope photo as I get "This page is not available" message from Picasa.
Try working backwards from the grids of the EL34's, blocking the signal path.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 20th September 2013, 12:12 PM   #4
Thank you, I've edited the post.
If I point the multimeter from ground to one of the anodes of the 12AX7 driver the oscillation stop.
I tried to place a 220pF capacitor from anode to ground but the oscillation won't stop......
Old 20th September 2013, 12:20 PM   #5
DF96 is offline DF96  England
Try adding cathode build-out resistors to the cathode followers. CFs can easily oscillate at RF frequencies - you may be seeing 700kHz squegging of a multi-100's MHz oscillation. The 12AT7 is a VHF valve.
Old 20th September 2013, 12:20 PM   #6
Try swopping the 12AX7 phase splitter with the drive. If that stops the oscillation, I would use an ECC88 instead of ECC83. It has a screen between the anodes or reduce the anode load resistors to 100K.
Old 20th September 2013, 12:26 PM   #7
pergo is offline pergo  Italy
pergo's Avatar
add grid stoppers in 12AT7 and 12AX7 near the grid pin. For example 1k.
Do you use the bypass cap on 100k feedback resistor?
Nessuno puņ farvi sentire inferiori senza il vostro consenso
Mr.P Electronics
Old 20th September 2013, 12:36 PM   #8
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
I dislike the grids of the top triodes of the cascode being unbypassed.
Also try a R in series with a C and them in // to anode loads of the cascode or between anodes (Plate to plate) to decrease high frequency gain (Say, a 100K in series to a 100pF from plate to plate).
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 20th September 2013, 12:42 PM   #9
Sorry, in the schematic is not showed a 33uF bypass capacitor for the voltage divider on 12AX7 grid.
I'll try 100k+100pF from anode to anode but this is a guitar amp arrangement...
Using a 12AT7 instead of 12AX7 stop the oscillation but only if the bias of EL34 is 40mA, if I rise to 50mA oscillation appear again....
I'm starting to think I've a ground loop... but the other amp is twin!!!
Old 20th September 2013, 12:44 PM   #10
what do you mean on build-out resistor?
I'm going to try all the mod suggested, thank you all!!
EL34 PP oscillatingHide this!Advertise here!
oscillating PP EL84 amplifier Danko Tubes / Valves 29 28th February 2014 07:05 PM
EL34 PP - again !!! Klaatu Tubes / Valves 9 15th August 2010 06:59 PM
Which do you prefer - EL84 UL PP or EL34 Triode PP - and why? ray_moth Tubes / Valves 4 23rd February 2007 12:22 PM
El34 PP Vs. El34 PSE alexmoose Tubes / Valves 47 6th September 2006 05:44 PM
