EL34 PP oscillating - Page 3 - diyAudio
Old 20th September 2013, 02:45 PM   #21
bingo! no NFB no oscillation! and now???
Old 20th September 2013, 02:53 PM   #22
popilin is offline popilin  Argentina
popilin's Avatar
Distributed capacitance in OPT, see post #19
Start with (3.-)
I do not suffer from insanity, I enjoy every minute of it. - Edgar Allan Poe
He has the most who is most content with the least. - Diogenes of Sinope
Old 20th September 2013, 03:22 PM   #23
I'm tryng but no way for now.... oscillation appear as I connect FB....
Why the other amp, the same identical amp, is rockstady stable???
Old 20th September 2013, 03:29 PM   #24
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Try reversing the secondary wiring, perhaps positive feedback in place of negative.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 20th September 2013, 03:31 PM   #25
alredy done, result in a squealing amp...
I need to find the old book of sistem theory or automatic controll....
Old 20th September 2013, 03:47 PM   #26
popilin's Avatar
The amount of GNFB that an amp will tolerate is governed primarily by its OPT.
Interaction between input stage and OPT determines the stability of an amp when GNFB is applied.
So I insist to adjust the value of C in the feedback loop.
As I said before, an RC between cascode anodes, may also help.
Edit: Put C=2uF in the output, probably both channels will oscillate.
Old 20th September 2013, 03:56 PM   #27
As my friend popilin said, first remove the cap in // with the R in the FB loop. The amplifier may be not unity gain stable at higher frequencies. Doing it (Remove C) you are warranting the same amount of feedback to any frequency. Then, when the amp is stable, try increasing this cap in small amounts, example, 100, 120, 150 pf or place a variable trimmer. Then, tune the amp using square wave as it has been said.
Old 20th September 2013, 04:14 PM   #28
pergo is offline pergo  Italy
pergo's Avatar
Add 10ohm+100nF Zobel at secondary winding
Nessuno puņ farvi sentire inferiori senza il vostro consenso
Mr.P Electronics
Old 20th September 2013, 05:21 PM   #29
kward is offline kward  United States
I've been through almost this exact same experience recently. Removing the cap in parallel with the FB resistor cleared up the oscillation. Adding small amounts of capacitance back in let me know where it became unstable. In my case, 330 pF made my amp oscillate (at about 1.5 MHz), but 220 pF was solid as a rock.
Old 20th September 2013, 06:58 PM   #30
with or without feedback capacitor the amp is not stable.
I've added RC between the two anode of the 12AX7, 33k + 100pF and no oscillation occour...
from the music I'm listening there is no kind of problem, excelent resolution as the twin amp...
the question is: how much is "legal" this solution on an hi-fi amp?
is the first time I build an hi-fi amp so I don't have any comparison with other project
oscillating PP EL84 amplifier Danko Tubes / Valves 29 28th February 2014 07:05 PM
EL34 PP - again !!! Klaatu Tubes / Valves 9 15th August 2010 06:59 PM
Which do you prefer - EL84 UL PP or EL34 Triode PP - and why? ray_moth Tubes / Valves 4 23rd February 2007 12:22 PM
El34 PP Vs. El34 PSE alexmoose Tubes / Valves 47 6th September 2006 05:44 PM
Copyright ©1999-2017 diyAudio
