CCS into a VR with Interstage question - diyAudio
Old 20th September 2013, 07:11 AM   #1
eeyore is offline eeyore  Australia
Default CCS into a VR with Interstage question
Hi, I am in the process of designing an 45 DHT amp using a C3g as the driver tube. The current intent is to use a 1:1 interstage transformer to couple between the C3g and the 45. I have a specific question regarding the use of a VR tube and CCS on the driver stage. My question is this, if I use a 0D3 to get a regulated 150 V plate voltage for the C3g.
In my understanding, in this situation, say we need around 10 mA for the 0D3 and the C3g is biased around 10 mA also. If I were to use a CCS before the VR tube and the interstage transformer, would I set the CCS at 20 mA, and the additional voltage swing and current swing would be provided by the interstage transformer. Am I right in this regard?
If one doesn't use a interstage transformer, I understand that the VR tube has to conduct the full range of current swing on the C3g tube. For example, if the swing is +/- 5 mA for the C3g biased at 10mA, and the would be 5 to 15 mA, therefore, the VR tube would need to be biased at 15 mA (10 mA minimum, plus 5 mA), so that with the plus and minus 5 mA, would not cause the 0D3 to have less than 10 mA across it. So, in this example, if I were to use a CCS, the CCS should be set to 25 mA.
Am I correct in my assumptions above? Or do I have it totally wrong? Thanks for any input.
DF
http://diy-audio-blog.blogspot.com
VR Tube Question coldcathode Tubes / Valves 7 6th December 2011 08:34 PM
Question about a VR screen supply athos56 Tubes / Valves 23 28th February 2009 03:09 PM
Interstage topology question rdf Tubes / Valves 23 8th May 2007 03:28 AM
shunt regulator using VR tubes (with ccs like g pimm) and circuit load jarthel Tubes / Valves 2 23rd April 2007 03:33 PM
Interstage resistor question Ralph Tubes / Valves 2 27th August 2003 09:36 AM
Copyright 1999-2017 diyAudio
