Rectifier and DC filtering relationship question
Old 20th September 2013, 12:10 AM   #11
Sea Biscuit is offline Sea Biscuit  United States
v on the c1 button?
Choose the value for C1?
I chose 10uF, just to see what it would do with a 5ar4. But I don't understand the graph...
Old 20th September 2013, 02:06 PM   #12
zelgall is offline zelgall  Canada
Add a resistor or choke after the cap and add another larger cap after the R or L. The ripple will smooth out considerably.
Old 20th September 2013, 02:12 PM   #13
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Originally Posted by Bob Richards View Post
By the way, rectifier tubes are obsolete.
What? Do you know rectifier tubes are still being manufactured?
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 20th September 2013, 02:48 PM   #14
Ok will do. But am I reading the graph correctly, that there's over 4v of ripple left on the DC, or does it not work like that?
Old 20th September 2013, 04:23 PM   #15
You're reading it right but the design is incomplete. You need the other components to provide the filtering you want. With a single cap and nothing else, you will have very high ripple. It's just a few clicks of the mouse so give it a try.
See the attachment for an example. This isn't optimum, just showing an example.
Old 20th September 2013, 05:36 PM   #16
Right. I do understand that it was incomplete. Was just an excercize in using that program... Thanks for the clarification on the graph.
Old 21st September 2013, 12:40 PM   #17
Ok, playing around with the PSUD a little more. For guitar amp applications, what is an acceptable amount of ripple... 1v? .5v? Less, more? Just trying to get an idea of what is reasonable.. One thing to note, I don't like my amps sounding too "tight".
A second question, What are those wavey patterns that smooth out from left to right? They take up more of the graph in the second image with another filter added on. Is this a graph that accounts for time and that is what the forms look like when it's first switched on?
Old 21st September 2013, 01:24 PM   #18
drlowmu is offline drlowmu  United States
Banned
You selected and were showing I for C1 which is CURRENT in Amperes.
Select V for C1 which is VOLTAGE in VAC !!
Have fun learning. PSUD is cool.
Jeff
Old 21st September 2013, 01:46 PM   #19
Yeah I did end up figuring that out.
How do I read the red lines for the power coming off of the rectifier in this image? It's all below zero?
And also, how do I determine if the R values are correct on the choke, caps, etc?
Old 21st September 2013, 06:58 PM   #20
Palustris is offline Palustris  United States
Palustris's Avatar
Add a current tap in parallel with C2. That will represent the load established by your output tubes so use an appropriate current, say 100mA. R2 represents the driver stage and can be a current tap also instead of the resistor. You will then look at the voltage waveforms on C2 and C3 which are in parallel with the loads.
Rectifier and DC filtering relationship questionHide this!Advertise here!
Independant Inductive DC Filtering. smithomo Solid State 0 26th March 2012 04:24 AM
newbie question : driver/output relationship, input sensitivity mahleriana Tubes / Valves 1 17th August 2008 08:10 PM
dc-filtering-ac-power-station jh6you Power Supplies 57 3rd June 2007 07:09 AM
How much filtering required for DC heaters? RockysDad Tubes / Valves 2 27th February 2006 08:45 PM
