diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   datasheet request (http://www.diyaudio.com/forums/tubes-valves/24261-datasheet-request.html)
mozikluv 15th December 2003 07:00 AM
datasheet request
hi,
can anyone provide with the datasheet of the ff. tubes?
1. 6SK7
2. 6BE6
3. 12AX7A
4. 6V6GT
5. 5U4GB
thanx
dhaen 15th December 2003 07:05 AM
The fountain of knowledge....
Frank's Electron Tube Pages
richwalters 15th December 2003 08:26 PM
couldn't agree more....rich
mozikluv 16th December 2003 02:45 AM
tubes specs
:confused:
thanx guys for the site, i got all what i need.
but what's "miniature high mu twin triode" this was from the 12ax7a:xeye:
ashok 16th December 2003 02:54 AM
What is "mu"?
Hi Mozikluv,
If you are going to be using tubes , you should (preferably) know how a tube works and all its parameters.
Quote : but what's "miniature high mu twin triode"
You shouldn't be asking this. Please check out the web for a page on the operation of a vacuum tube. The explanation is not difficult but long . I can't remember the URL's but someone could help with that.
Cheers.
ashok 16th December 2003 03:32 AM
Some URL's.
I checked out a few URL's.
You might find them useful.
http://www.geocities.com/summitamps/vtbasics.html
http://www.svetlana.com/docs/tubeworks.html
http://www.lh-electric.4t.com/tutorials.htm
http://www.eecs.umich.edu/~mmccorq/t...roduction.html
Have fun.
Cheers.
mozikluv 18th December 2003 01:31 AM
tube amps
:) hi ashok
thanks for you reply, i will check out those sites you have recommended. am not that knowledgeable when it comes to tubes. the only time i had experience on tubes was way back in my high school days and it was purely assembling only and when it comes to particular functions am a bit lacking in know how. so i will just have to review my tubes.:)
ashok 18th December 2003 02:22 AM
Hurry up !
Hi Mozikluv,
Read through those pages a few times and you will get the hang of it. Then you can start shooting the questions and designing your first few circuits. You'll find it pretty interesting. You don't need to know too much to build some working circuits. Refining them might take more time. There is enough help on this forum.
Have fun.
Cheers.
ashok.
Don't forget to do a search for circuits on the forum first. There are quite a few out there.
Brett 18th December 2003 05:22 AM
Re: What is "mu"?
Cheers.
Simply, "mu" is the amount of inherent amplification in a given tube. But a really good, clean and easy to understand explanation of hoe triodes work and the most common and basic circuit application appears here and there is a PDF of the several html pages here
minature - means it's a small botlle, usually nine pin, smaller than the 8 pin octals that were most common for a long time.
high mu - means high gain, or lots of amplification. Note this is a relative term and the way a given tube is used in the circuit can vary the amount of actual amplification that will result
twin triode - there are two seperate triodes within the one glass envelope (tube)
mozikluv 18th December 2003 06:50 AM
tube amps
:) hi,
thanx for the replies guys. the reason why am asking all the queries is bcoz i have this stereo tube amp which i have assembled quite a long time ago and it's in the dust bin for so long. the tube #s that i have posted are all used in that amp. as soon as i have the proper time i would like to revive that. i will have to draw up the schem for that coz i have lost it or probably thrown it away. once i have the circuit drawn i will post it here and have you guys scrutinize and comment on it.:)
Resources saved on this page: MySQL 18.75%
