OTL question - diyAudio
Old 8th September 2013, 10:03 PM   #1
Default OTL question
I saw this circuite on line and wondered if I subsituted a 6c33-b for the
6as7's using a 5ohm cathode resistor about how much power would it be
good for. I know using a pair of 6c33c-b tubes at 150v is good for about
25 watts but what would hapen if I just used 60V.
Old 8th September 2013, 10:16 PM   #2
JonSnell Electronic's Avatar
As your choice of valve is designed to run at 400volts, maybe there could be a bit of a problem. A valve used as a diode drops around 75volts across the Anode to Cathode so not a great deal of headroom for a valve of this design running at such a low voltage.
Support for PMC DS-001, (Hypex) UcD400,Valve Equipment and designs both new and old. www.jonsnell.co.uk
Old 9th September 2013, 07:10 PM   #3
Ketje is offline Ketje  Belgium
Ketje's Avatar
Since there are two triodes in one 6C33 you need 4 tubes.With a load of 8ohm I think around 4W sine output.
Mona
Old 9th September 2013, 07:15 PM   #4
kevinkr's Avatar
A pair on +/-140V rails will give you about 20W into => 8 ohm load. (From experience)
A single 60V supply is not going to cut it.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 9th September 2013, 09:22 PM   #5
Ketje's Avatar
Yes,I supose 20W is possible but how long does the valves last ?
By the way,the schematic shows +/-60V
Mona
OTL question woody Tubes / Valves 4 25th September 2008 12:46 AM
Old OTL circuite question woody Tubes / Valves 1 4th December 2006 06:57 PM
OTL PS question!! satelitis Tubes / Valves 23 19th November 2004 05:17 AM
OTL question. jim Tubes / Valves 2 1st July 2004 02:49 AM
OTL Output Cap Question Andrewbee Tubes / Valves 6 12th January 2004 08:45 AM
Copyright ©1999-2017 diyAudio
