OPT as PSU filter??? - diyAudio
Old 5th September 2013, 03:58 PM   #1
Default OPT as PSU filter???
Recently there was a debate between our fellows at our local DIY forum.
One guy came up with a typical PP schematic without filter choke on B+ line and claimed that besides being the output device, each half of the OPT also serves as B+ filter for its power tube. He even brought up an old local technical book with similar statement, however without any further explanation.
This is clearly incorrect for me, but I couldnt find some clear and persuasive silencers to point out that the OPT does not have any filter action but the hum/noise cancelling exists only because this is a PP stage.
Can you guys help?
Great thanks,
Duong
Old 5th September 2013, 04:02 PM   #2
DF96 is offline DF96  England
Yes, a valve PP output gives some ripple cancellation because it is PP but the ripple is common-mode. This is not because the OPT acts as a smoothing choke!
Your friend may be confused by hum cancellation tricks sometimes used in domestic radio receivers. A tap on the OPT was used to reduce hum.
Old 5th September 2013, 10:32 PM   #3
multi is offline multi  Australia
i have lots of Poor quality PA output transformers used with PP KT66.
Wondered if you could use them as chokes.?
Phil
Old 6th September 2013, 05:14 AM   #4
Regenpak's Avatar
@DF96: and from the tap on the OPT it goes on to power the low-power circuitry (IF, mixer) in these receivers. In a PP amp the transformer is only the plate load of the output tubes, nothing else. There is no filtering action from the OPT. Filtering is done by the push-pull action of the circuit. The OPT trick might work in a cheapskate SE amp
Tjerk, 9ZZ
Old 6th September 2013, 02:55 PM   #5
Can you enlighten me on this? I'm not so familiar with this hum reduce trick.
Regarding using the KT66 PP OPT as filter choke; I think the answer is yes but since the OPT has no air gap, it should be used in a way so that each half supplies for a channel. As long as current comsumptions are equal/similar for both channel, this method can give adequate result. However since the transformer was used for KT66, current rating wont be high.
Duong
Old 7th September 2013, 03:38 AM   #6
You can take measurement of ripple value (in mV ac) at B+ and Plate for 2 cases in which both power tubes run and one of them runs (remove one power tube). So I think you get the answer.
Note: doing this if 2 power tubes run with separate cathode resistor.
Will you do ?
Old 7th September 2013, 07:06 AM   #7
Will you do ?
Hi "bác sĩ", nice to see you here!
This wont do because if you pull out one powertubes, the core of th OPT will be saturated by the DC current of the other tube and the measurements wont make sense.
However I intend to do some measurements on a SE circuit, this will remove the hum cancelling effect which happens on PP and make the results clearer.
Any other ideas?
PSU filter stajo Pass Labs 2 7th July 2013 03:45 PM
Indcutor in CRC filter of PSU frags Pass Labs 3 4th October 2010 03:56 PM
Which filter caps for a PSU? fastasulike Power Supplies 3 12th December 2009 10:44 PM
AC filter for PSU borges Everything Else 4 31st January 2007 01:22 PM
different psu filter topologies ? metebalci Tubes / Valves 4 4th August 2004 07:53 AM
Copyright ©1999-2017 diyAudio
