Choke ratings and resistor values in choke input supply?
Old 5th September 2013, 04:53 PM   #11
deicide67 is online now deicide67  United States
What about tube rectification? I'm not a fan, but that should slow the spikes, etc.
This is for a PP 6550 amp. Would a GZ34 or 5AR4 be a better choice?
Old 5th September 2013, 05:29 PM   #12
TheGimp is offline TheGimp  United States
TheGimp's Avatar
GZ34 and 5AR4 are equivalent.
Did you mean 5R4? They look like a good candidate.
Old 5th September 2013, 05:42 PM   #13
Hi, yes. 5R4 Sorry.
I was thinking about two in parallel.
Old 5th September 2013, 05:52 PM   #14
homeskillet is offline homeskillet  United States
homeskillet's Avatar
Pretty tall order for a tube rectifier. I'm getting by with a 5U4GB at 500 volts and I'm sure it's just sqeeking by. All the charts really narrow down with higher current draw and voltage with choke input. The only thing i like about the tube rectification with it is that the rectifier being on the edge will blow probably sooner than ss diodes that might keep delivering should something go wrong. Like an expensive fuse. The higher the voltage the scarrier it gets. 500 volts is my limit.
I don't know how it would behave with a push pull. All I can say is try it and see. What i can say for sure is you'll see less voltage drop the more class a push pull you run.
Old 5th September 2013, 06:08 PM   #15
You are probably right to stick with SS rectification.
Someone has also suggested a fly back diode as well as snubber caps across the first inductor to help with peaks.
I think this is the layout I'm going with. I will cut the plates today so I am committed or, this could go on forever.
Old 5th September 2013, 07:37 PM   #16
I'd say definitely breadboard it before committing any materials. From what I've seen on the supplies I've made is that it prob won't give the regulation you want even with SS rect. I believe the trick for regulation is using a swing choke choke and adjusting many more factors for a range of current draw. No small task.
Sorry. This is occurring to me slowly since I just like playing with and maybe even more talking about choke IF power supplies . Seems to me like a cap input supply with active shunt regulation would serve you better and be less hot, heavy, and scary and prob actually work well.
I've got to scoot. I just had to say something. That's some pretty stuff you have there and it would be awesome if it worked well too. You'd have to get advice from someone other than me for a shunt regulator though. Definitely get a second or third opinion. -Fred
Old 5th September 2013, 07:41 PM   #17
TheGimp's Avatar
Simulate the power supply in LTSpice. Nothing goes Boom! if it is a bad iteration.
Old 5th September 2013, 08:34 PM   #18
I do not have LTSpice. I have PSD II.
Old 5th September 2013, 08:37 PM   #19
TheGimp's Avatar
Actually, PSUDII probably works better.
Old 5th September 2013, 08:42 PM   #20
Never mind. I forgot that the power supply in our PC was taken out by a storm. Ironic
Choke ratings and resistor values in choke input supply?Hide this!Advertise here!
Bleeder Resistor for Choke Input Supply Magz Tubes / Valves 5 19th June 2012 03:30 PM
choke input power supply vitalstates Tubes / Valves 10 24th February 2012 01:03 PM
Choke input power supply, capacitor ratings 00940 Tubes / Valves 14 7th July 2009 05:52 PM
Choke rating for choke input duty cbutterworth Tubes / Valves 14 9th November 2007 04:43 PM
Resistor-Input vs. Choke-Input vs. Cap.Multip. Blitz Pass Labs 13 26th September 2003 04:59 AM
