Novar Spud :: A 0 sweep tube Spud with PCB
Old 29th November 2017, 10:48 PM   #161
smoking-amp is offline smoking-amp  United States
smoking-amp's Avatar
Here is another little trick.
I put Novar pc mount sockets on Pete Millett's 9 pin Noval prototyping boards. Then I made the Noval sockets it came with (specify un-attached) into an adapter using 40 mil Keystone 1405- 1/2/3 pins (Mouser has these). Now it works for Noval or Novar, and it provides convenient scope probe clip-on contacts for Noval tubes:
Since Novar fits too, I may make some Novar to Novar socket adapters also using the 40 mil pins (just like the Noval adapter shown), then I'll have convenient scope probe clip-ons for Novar too.
Remember the EL Faro.
NTSB: The captain "was overly confident, would not listen to the advice of his officers".
Old 30th November 2017, 05:28 AM   #162
tomchr is offline tomchr  Canada
tomchr's Avatar
That's a pretty neat trick.
Modulus-86: 40W/8Ω @ 0.000061% THD. HP-1: 3W/20Ω, 450mW/300Ω @ 0.000032% THD. DG300B and Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 30th November 2017, 05:42 PM   #163
OT: More little tricks
I used Octal Wafer plugs ( Ebay) to make adapters for 7 pin B7G and 8 pin sub-mini tubes. I used a 7 pin PC tube socket, and an old Augat 8 pin Teflon round IC socket for each. The 7 pin PC sockets fit perfectly into the Octal Wafer pins. The Augat IC socket required wire spreaders to fit the Octal Wafer pins. The gray Octal relay sockets make for cheap wired prototyping bases. I also put some looped copper wire scope clip-on contacts around the sockets.
Old 1st December 2017, 05:30 AM   #164
tomchr's Avatar
I generally use a piece of scrap PCB with some tube socket mounting holes and turret strips for prototyping. It's not pretty but it does the job until I lay out a PCB.
Tom
Novar Spud :: A 0 sweep tube Spud with PCBHide this!Advertise here!
6C45P Spud serengetiplains Tubes / Valves 1 12th September 2015 02:24 AM
Th spud jblauvelt Subwoofers 75 28th May 2015 10:31 PM
This SPUD's 4 U roline Tubes / Valves 12 23rd February 2013 03:51 AM
Spud: what, again!?! squiffiness Tubelab 118 6th November 2012 02:27 PM
Spud anyone? Tubelab_com Tubes / Valves 88 12th January 2010 01:22 AM
Copyright ©1999-2017 diyAudio
