E810F filter buffert in dac Q - diyAudio
Old 13th December 2003, 09:07 PM   #1
Default E810F filter buffert in dac Q
I am looking at this dac:
Tubedac tda1541a
the author says:
The values of the filter section is calculated for the version without Transformers.
I want to build this dac using the 1:15 transformers and 2x75mH inductors.
Can anyone helo me pointing out which components belongs to the so called "filter" and what values should i try change them to?
the schematics can be found here:schematics
/kasra
Old 13th December 2003, 10:29 PM   #2
diyAudio Senior Member
fdegrove's Avatar
Not sure what exactly it is you want to do.
While I can point out the filter components, I'm at a loss as to where the 75mH chokes come from?
Did you post the wrong URL for the second link?
Frank
Old 14th December 2003, 09:46 AM   #3
fdegrove:
Thank you for the reply.
I once had contact with the authour/designer, he said that using 1:15 transformer, one had to change the 3.3mH inductors to 75mH. And recalculate the filter.
The second URL is just a bigger picture of the schematics. of the version without 1:15 transformer. (eventhough its there on the schematics, bypassed?)
He also has a version one of this dac using e182cc instead of e810f, on that schematics he uses the 1:15 and 75mH.
with e182cc
/kasra
Old 14th December 2003, 12:03 PM   #4
fdegrove's Avatar
So you want to use the Version 1 filter in combination with the Version 2 E810F tube?
As Version 1 uses the 1:15 ratio xformer you can use the same filter:
Frank
Old 14th December 2003, 03:01 PM   #5
fdegrove:
thank´s alot!
need help wana change 60-Hz twin-T notch filter to 279 Hz filter prorms Solid State 0 9th February 2008 11:38 PM
E810F: RIAA circuits waltube Tubes / Valves 8 17th December 2007 07:50 PM
active filter from rod elliot and sub filter questions wuffer Parts 0 2nd October 2005 01:12 PM
E810F in triode cathode_leak Tubes / Valves 18 10th May 2005 02:56 PM
chassis-mounted filter or IEC plug filter jarthel Solid State 7 11th March 2002 10:17 AM
Copyright ©1999-2017 diyAudio
