6EJ7/EF184 datasheet with plate curves:
http://frank.pocnet.net/sheets/030/e/EF184.pdf
Looks like 6JC6 is a bit sharper cutoff toward the knees, and 6EJ7 has 2X the plate resistance.
I used the 6JC6A in one of my early amps, as it was one of the better performers in Pete Millett's pentode shootout. I had no complaints. I don't remember if the 6EJ7 was on his short list as well, but I've gotten a bunch on spec and will end up using them one day. The 6EJ7 is supposed to make a nice triode when strapped for it. The varieties with the mesh shield also look good.
