Old 31st August 2013, 02:59 PM   #1
7n7is's Avatar
Default Russian to English Translation needed
Can someone tell me what it says (translated to English) under the chart on the top right of this datasheet. It looks like current in milliamps is on the vertical axis, but I can't tell what is on the horizontal axis. Ua doesn't look like voltage. There's some writing below the chart that I'd like to know what it says.
Its over here, too.
http://klausmobile.narod.ru/td/data/_6h7b.GIF
http://www.klausmobile.narod.ru/td/l...nverters%20etc
Old 31st August 2013, 03:04 PM   #2
Mooly's Avatar
This type of problem has cropped up before. You could try scanning the document with OCR (optical character recognition software such as Abbyy that is often included with printers/scanners) and then copy and paste the text into google/bing translate.
A simulation free zone. Design it, build it, test it.
Old 31st August 2013, 03:08 PM   #3
avp1 is offline avp1  United States
Its over here, too.
It is plate voltage. Graph shows plate current vs. voltage around (+ and -) 0 volts.
Old 31st August 2013, 03:24 PM   #4
Regenpak's Avatar
This is a detector diode, so yes, it's Ua (U stands for "Ursache" in German, or cause) which indeed is plate ("Anod") voltage.
Old 31st August 2013, 03:41 PM   #5
Blaireau's Avatar
Right, and the anode voltage has been measured with a 40 K anode load resistor. (сопротивлений наргузки 40 ком)
http://constructions.f6fkn.com
Old 31st August 2013, 05:28 PM   #6
7n7is's Avatar
I was wondering why there's current when the voltage is zero. Theoretically, when voltage is zero, current should be zero.
Old 31st August 2013, 06:10 PM   #7
работник
Rod Coleman's Avatar
It's a detector diode designed for "miniature equipment".
The graph is (as already noted) current vs voltage.
The graph is labelled "the average initial anode characteristic", ie typical performance when new.
Old 31st August 2013, 06:52 PM   #8
7n7is's Avatar
Does Cyrillic work here?
усредненная - averaged
начальная - primary/initial
анодная - anodic
характеристика - characterization
при - at
сопротивлении - resistance
нагрузки - load
40 ком - 40 Kohm (assuming ком means Kohm)
(using Google Translation and Russian Keyboard OnLine with Spell Check (On-Screen Cyrillic Virtual Keyboard) for typing Cyrillic characters)
Old 31st August 2013, 09:50 PM   #9
Miles Prower's Avatar
Theoretically. However, in practice, electrons don't leave the cathode with zero velocity. Electrons that leave with an initial velocity will still hit the anode even when the Vpk is zero, or even slightly negative. It's similar (but not identical) to the reverse leakage current through a reverse biased SS diode.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 2nd September 2013, 12:14 AM   #10
7n7is's Avatar
If you look at the first graph on the third page here
http://www.wdv.com/Electronics/Radio...d/pdf/6AL5.pdf
you can see that plate current is zero when voltage is zero (on the graph)
I'm wondering how the 6H7b would work in place of a 6AL5 in a ratio detector, for example. I have a couple 6H7b tubes and two 7 pin minature tube sockets which can be soldered to a 6H7b tube and used as a replacement for a 6AL5. Another idea I'm interested in trying is replacing the solid state diodes in a Pilot 100 stereo demodulator with vacuum tube diodes to see if the distortion is lower with tube diodes. Vacuum tube diodes are foward biased at a lower voltage compared to solid state diodes (about 0.3 volts for Ge and 0.6 volts for Si).
http://members.shaw.ca/pacifictv5/pilot100.jpg
Japanese to English translation Reeler Solid State 32 24th January 2012 12:17 AM
mini onken english translation vega65 Multi-Way 42 31st October 2011 04:40 PM
Russian-English Translation of 4P1L datasheet 316a Tubes / Valves 16 6th September 2011 12:09 AM
Translation - from dutch to english Tomv Multi-Way 8 15th June 2005 07:11 PM
german to english translation HELP! JC Fardo Everything Else 8 21st March 2005 08:46 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
