Aikido preamp power supply
Old 29th August 2013, 09:00 AM   #1
bekim is offline bekim  Albania
Default Aikido preamp power supply
I am building Aikido preamp and I red many reviews and posts regarding the power supply which, most of project builders have used solid state designs.
I found this complete module in ebay, can anyone give any idea is this good PS for Aikido?
Anodenspannungsversorgung Platine | eBay
Schematics
https://picasaweb.google.com/vbkolse...04948065234066
thanks
Old 29th August 2013, 09:49 AM   #2
Gost22 is offline Gost22  Bolivia
Banned
Schematics
thanks
Hello!
For recommendations for given this power supply fits your Aikido tube preamplifier give the schematic your preamp!
Otherwise, this is essentially the power supply of sematic is universal and can be used for each tube pre-amplifier.
cheers!
Old 29th August 2013, 10:03 AM   #3
hcbonfim is offline hcbonfim  Brazil
Hi, I use Salas HV2 shunt regulator (for +B) and it´s great,
There is a lot of threads in this forum,
cheers
Old 29th August 2013, 10:35 AM   #4
Hi
Ok, on schematics link you can see the design of PSU, I have no idea why ebay link isn't appearing..
My concern is with this PSU, is it ok if in gnd I can connect earth from socket?
Reason why I'm asking is that, some sources I use will have earth connected to the gnd of the power supply.
Old 29th August 2013, 11:30 AM   #5
Banned
Thumbs up Quality PSU for tube preamp!
Hi Bekim!
Here schematic quality power supply for yours Aikido tube preamp!
Enjoy!
Old 29th August 2013, 05:30 PM   #6
Originally Posted by Gost22 View Post
Hi Bekim!
Enjoy!
Thanks for the schematics.
This circuit looks ok, just "too" many bipolar transistors on it
I am thinking to use this design for preamp, looks simple and I can purchase pcb in ebay. Anyone, do you think is ok this design, attached in my post.
thanks
Old 29th August 2013, 05:52 PM   #7
SigFire is offline SigFire
Default 1N4148 as a rectifier for Hi-Voltage ?
Don't get me wrong, Bekim, but
don't you think 1N4148 ( 75V-100V, 75 mA-200mA depending on what
database we have) are somewhat too weak for the rest of that PSU ?
Similar psu tend to use 1N4007/UF4007/SF4007 or "tougher" diodes.
Greez
Siggi
S.K.
Old 29th August 2013, 06:19 PM   #8
Stixx is offline Stixx  Germany
Stixx's Avatar
The diodes are in fact too weak ...
Why not use a Maida reg for the Aikido..?
This is more than up to the task, and even better, I could sell you one ready built!
I used this for my Aikido Parafeed headphone amp but later replaced it with a Salas shunt reg. When you are interested it can be yours for 20€ plus shipping. It is set for 210V out (up to 200mA at least) but can be set for other voltages. It just needs a transformer and CRC prefilter.
Old 29th August 2013, 06:57 PM   #9
Thanks for reply.
Actually those 1N4148 are 1N4007, might be typo in schematics.
Here you find schematics:
PCB I found in ebay.de [I hope I post the link right this time] after http:// put ebay dot de
http:// Elektronik, Autos, Mode, Sammlerstücke, Gutscheine und mehr Online-Shopping | eBay /itm/Anodenspannungsversorgung-Platine-/110397932032?pt=DE_Elektronik_Computer_TV_Video_El ektronik_Verst%C3%A4rker&hash=item19b43ac200
Reason I am after mosfet is, soft start, otherwise your designs are great.
thanks
Old 30th August 2013, 04:37 AM   #10
Banned
thanks
And this schematic can use for your tube preamplifier, as not cost much!
cheers!
Hi Stixx!
That the DC input voltage (Vin =?) should be on this circuit for the output to be get Vout = 250Vdc.
Is STW13NK60 (IRFS450) can be replaced with IRF830?
thank you!
Aikido preamp power supplyHide this!Advertise here!
Need help with Aikido power supply JayH3 Power Supplies 3 22nd June 2008 02:48 PM
Aikido Power Supply dmk Tubes / Valves 11 23rd August 2007 02:27 AM
Hot running regulated dc filament supply for aikido preamp 2004ex Tubes / Valves 6 27th September 2006 12:38 PM
Aikido Power Supply dr._sleep Tubes / Valves 13 27th August 2005 04:57 PM
