Aikido preamp power supply - Page 2 - diyAudio
Old 30th August 2013, 08:21 AM   #11
bekim is offline bekim  Albania
Originally Posted by Gost22 View Post
Hi Bekim!
Here schematic quality power supply for yours Aikido tube preamp!
Enjoy!
Gost22,
I am considering schema you provide.
Do you apply any heatsink to transistors? My transformers output is 200V AC, I=~100 mA, and I need output 240 - 250V DC.
Old 30th August 2013, 11:55 AM   #12
Stixx is offline Stixx  Germany
Stixx's Avatar
Hi Stixx!
That the DC input voltage (Vin =?) should be on this circuit for the output to be get Vout = 250Vdc.
Is STW13NK60 (IRFS450) can be replaced with IRF830?
Input voltage should be about 20V higher than the desired output, so ~ 270V.
Don't know about IRF830.... the classic IRF840 would be better.
Old 31st August 2013, 05:30 AM   #13
Gost22 is offline Gost22  Bolivia
Banned
Hi Beikim!
Use 2 a transformer, Tr1 of 15 .. 20VA with second hand of 13 ... 16Vac for power supply heater tube and other transformer Tr2 of 4 ... 6VA the second hand of 12Vac. The latter connect with PRIMARAR the first secondary transformer of 15Vac, so that otherwise get around 220V.... 240Vac for voltage + B node tube. (See schematic Figure-1).
cheers!
Old 31st August 2013, 05:41 AM   #14
Banned
Hi Stixx!
See table below:
thanks!
Old 31st August 2013, 06:39 AM   #15
Banned
Bekim, if you want to complete a quality tube pre-amp I recommend this to with ecc88. Not very expensive for design, but provide great tube sound!
Enjoy!
Cheers!
Old 31st August 2013, 07:56 PM   #16
Gost22.
Thank you for schematics and information provided. Nice design and looks cool.
What I like most is timer.. ;-) I think is set 30 seconds as delay.
Great!
Old 1st September 2013, 04:58 AM   #17
Banned
Bekim, if you do this tube pre-amp on this schematic, the articles are you satisfied with its tube sound?!
Good luck!
Old 9th September 2013, 10:14 AM   #18
Good luck!
Gost22,
I put together this circuit and if I want to add choke in output like 10H, do you think this is proper connection of the choke?
thanks
Old 18th September 2013, 02:00 PM   #19
Anyone thinks is good place to put choke as marked on schematics...???
Appreciate your feedback.
Old 19th September 2013, 01:21 AM   #20
Banned
The inductance of the coil (L1) can be 10 .. 20H for current> 100mA
Need help with Aikido power supply JayH3 Power Supplies 3 22nd June 2008 03:48 PM
Aikido Power Supply dmk Tubes / Valves 11 23rd August 2007 03:27 AM
Hot running regulated dc filament supply for aikido preamp 2004ex Tubes / Valves 6 27th September 2006 01:38 PM
Aikido Power Supply dr._sleep Tubes / Valves 13 27th August 2005 05:57 PM
Copyright 1999-2017 diyAudio
