ECL82/6BM8 as rectifier?
Old 12th December 2003, 09:31 PM   #1
svokke is offline svokke  Belgium
Default ECL82/6BM8 as rectifier?
In this article at TNT-audio the author writes that in his preamp (Korato KVP-20) the ECL82 tube is used as rectifier. Checked it here at korato.com and it just says that it is used in the power supply.
What's going on here. Why is there a triode/pentode sitting in the powersupply. Is it used as some kind of regulator?
In illusion comfort lies
Old 12th December 2003, 10:45 PM   #2
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
I didn't see the word "rectifier" mentioned, just "power supply".
In fact the ECL82, and similar triode - pentodes make good power regulators, and I think this may be one applied case. The triode section as an error amp, and the pentode section as the series pass element.
It does seem a bit of a shame to use one that's good for audio in a PSU, when there are others Eg ECL80, ECL85/805 that are just as suitable for regulators, but not so good for audio.
BTW You can use any triode or pentode as a rectifier, just watch out for grid power dissapation. It has been suggested (on this forum I think) that a controlled rectifier could be built this way.
Old 12th December 2003, 10:46 PM   #3
Brett is offline Brett
Brett's Avatar
Most likely it's part of a series regulator, and as they don't mention a specific rectifier tube, I'll bet it uses SS rectification.
I suppose it could be used as a rectifier, but with millions of decent NOS rectifiers, plus the apparently increasing quality of the Russian and Chinese made units, why would you?
Old 13th December 2003, 12:49 AM   #4
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Yes, and from a manufacturers' POV they picked a triode/penthode that's still manufactured up to this day.
The ECL80, ECL85/805 aren't as far as I know.
I very much doubt they'd use it as a diode.
Frank
ECL82/6BM8 as rectifier?Hide this!Advertise here!
ECL82 (6BM8) PP Stereo Family_Dog Tubes / Valves 27 30th May 2009 06:21 PM
6bm8/ECL82 vs EL84 akimball442 Tubes / Valves 15 26th January 2009 01:34 PM
6bm8 / Ecl82 Pse & Srpp argo Tubes / Valves 4 8th April 2005 09:47 PM
Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? zxx123 Tubes / Valves 4 21st February 2005 04:02 AM
ecl82/6bm8 push pull special designs Glass_painter Tubes / Valves 1 19th April 2003 06:45 PM
