6EB8\6GN8 P-P Output 2*12w Class-B - diyAudio
Old 18th August 2013, 08:28 PM   #1
TURING is offline TURING  China
Default 6EB8\6GN8 P-P Output 2*12w Class-B
Posted this post, it is expected very few people will respond. Because it was too upset it. However, I do it well, and it is very good, in the output 2 6w when distortion is small, but has a good sound quality. Maximum output can reach 2 12W. Do not believe? Then you can try.
Shell is the CD drive of the shell, the entire tube amp with palm size.
Of course, a more powerful vacuum is entirely possible. I still want to use a smaller power vacuum tube for greater output.
As a result of the CLASS-B status, the whole tube amp static power consumption is very small.
Old 18th August 2013, 08:34 PM   #2
tubelab.com's Avatar
I believe, because I made one. Try the 6HZ8. It has the same pinout but more power, with slightly different bias. It is physically bigger so it may not fit in your chassis.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 18th August 2013, 08:50 PM   #3
Class-B too?
Dude, my bosom friend ah! ~
The thought that "unprecedented and no latecomers" it.
Old 18th August 2013, 09:24 PM   #4
Class-B too?
I designed a circuit board for use as a driver for some big sweep tube experiments. The board was designed to use any of the tubes that have the "9DX" pinout. I had 6GN8's in it for a while, and I have tried about 12 different tube types with 6BA8's in the board right now. I am using them for lower gain. I ran the board into an OPT and cranked it to see how much power it would put out. While not technically pure class B because there was a few mA of idle current, it was biased rather cold to boost the efficiency. I got about 15 WPC with the 6HZ8's. The board is now being operated in class A with mosfet followers for use as a driver in some high power class B type experiments.
There are a few of us here that have been experimenting with operation at the edge of class B to boost efficiency. Most of these experiments use TV sweep tubes and lots of clean power is the goal.
I have been working with class B type stuff for about 10 years. look at this thread for the latest experiments using this board:
Show me your screen drive circuits
Old 19th August 2013, 04:38 AM   #5
Junm is offline Junm  Philippines
Junm's Avatar
Send a message via Yahoo to Junm
hi turing, can you show your schematics..i also have 8kr8's ...i think it can fit the bill.
Old 19th August 2013, 06:49 AM   #6
11k, not shown, a negative feedback.
Old 19th August 2013, 06:50 AM   #7
Regenpak's Avatar
Schematic would be simple: one triode voltage amp, another triode phase splitter and then both pentodes as PP power stage. Cute little amp. Being European I'd use ECL82 which alas is not pin compatible.
Edit: hah- spoke too soon
Old 19th August 2013, 06:56 AM   #8
Can you upload your schematic?
Old 19th August 2013, 07:02 AM   #9
ecl82? good tube! why not ecl86?
Old 19th August 2013, 07:10 AM   #10
Regenpak's Avatar
Why not indeed! With almost double the allowable plate dissipation (9W) a pair of ECL86s will easily produce 14 watts of power with 300V supply voltage.
what to do with a 12W 600ohm to 4/8 ohm output transformer? razorrick1293 Tubes / Valves 24 9th February 2013 03:48 AM
2SK135 - 2SJ50 -12W buzz2 Solid State 4 12th September 2011 05:24 PM
Single 6EB8 tube kit? Mike3 Tubes / Valves 4 11th September 2011 06:34 PM
single-tube (6GN8) amplifier? geekysuavo Tubes / Valves 15 1st May 2008 08:59 PM
Mills 12W, how hot do they get? zzz Parts 3 24th September 2003 09:46 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
