Octal Preamp Triode Thoughts (IDHT's) - diyAudio
Old 16th August 2013, 03:09 PM   #1
Default Octal Preamp Triode Thoughts (IDHT's)
I'm building a preamp using a very basic SE design to drive a Dynakit ST35.
It has an input impedance of 500K. My main source has a 200mV RMS output...so I will need some gain to bring it to 1V RMS.
Any thoughts about using a 6K5gt for a preamp or phono stage? Mu of 70.
I also have a 7F7 (double triode) and access to more- Mu of 70.
Also any thoughts of 6C5g's vs. 6J5gt's? Are they too close to warrant changing from one to another?
Any thoughts on other IDHT octal triodes would be awesome- especially single triodes.
Old 16th August 2013, 04:02 PM   #2
kevinkr's Avatar
Both 6C5 and 6J5 would be an excellent choice for a simple line stage. See which you like best.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 16th August 2013, 05:01 PM   #3
You mentioned the Loctal 7F7, which is electrically equivalent to the Octal 6SL7. An interesting Loctal medium mu twin triode is the 7AF7. The advantage of this type is its 300 mA. heater draw. The 7AF7 makes a fine common cathode voltage amplifier. However, its relatively low gm is a warning against cathode follower service.
Eli D.
Old 16th August 2013, 06:41 PM   #4
Vinylsavor's Avatar
Hi!
Is this for a line stage or phono or both?
In terms of high mu octals I like the 6SF5:
VinylSavor: Tube of the Month : The 6SF5
and the 6SC7 (both sections paralleled):
VinylSavor: Tube of the Month: The 6SC7
I used both of these in phono stages with success.
For line stages I like the 6AH4:
VinylSavor: Tube of the Month: The 6AH4
Bets regards
Thomas
http://vinylsavor.blogspot.com/
Old 16th August 2013, 09:31 PM   #5
Thanks for your responses.
Just picked up a pair of 6J5GT's for $6.50ea.
Has anyone tried the 6K5G in a phono stage...or any audio?
It has a high Mu...low heater current draw (0.3amps). It's curves look good- if I'm looking at them correctly.
I tried it in a line stage with a clean response...more in the highs...but I'm interested in others' comments and or experiences.
Old 29th March 2015, 09:06 PM   #6
alexkhar's Avatar
Send a message via Skype™ to alexkhar
Hello.
I use 6K5GT as driver in SE Amp. Ua=230V, Ia=1,17 mA. Sound is very clear so I like it.
Akita 12V preamp thoughts prezden Tubes / Valves 13 23rd August 2013 03:00 PM
Aikido Octal Preamp Glassware TCJ with regulated supplies mattattnet Swap Meet 1 4th October 2011 03:05 AM
hybrid amp with dht or idht inputs? AudioGeek Tubes / Valves 0 1st January 2011 05:04 PM
thoughts about a 'universal' preamp ErikdeBest Tubes / Valves 16 30th March 2010 09:56 PM
I want to build a preamp for my dad.. thoughts? 240z4u Tubes / Valves 32 22nd April 2009 02:32 AM
Copyright ©1999-2017 diyAudio
