Need Help - Monoblock Power Amplifier EL 34
Old 30th July 2013, 03:38 PM   #11
Regenpak is offline Regenpak  Netherlands
Regenpak's Avatar
Phew! At least the XFMRs are still there. You may want to leave them as is only redo the covers with black paint. Must be local production as Philips never used transformer covers.
It looks like someone already had a go at it. The black caps are not original, nor is the white ceramic resistor. The green resistors with the value printed on them are also not Philips but prolly original. The mustard capacitors are famous and original as are the blue electrolytics. The resistors in the power supply look tired and should be replaced. Can't figure out the GZ34s (parallel or something else?). Oh, and all caps on the top side of the chassis (big cans) will be toast.
A shot from the front panel would help, as some more closeups. The cover over the tone control (ECC83, prolly standard Baxandall) is in the way as well. And the EF86 preamp is completely hidden by the shielded volume control (at least I think that's what it is). Oh, stick to one amp when you make more piccies. The better looking one...
Old 8th August 2014, 04:55 AM   #12
apnneto is offline apnneto  Brazil
After awhile, I'm back to this project. I thought it was a Mullard 5-20 mod, but after drawing the wiring diagram from the circuit, I know that this is not the amp.
Some days ago I was starting to work on a ground plan, and then I had to stop.
Now I'm totaly lost. I searched the net looking for similar schemes and informations about this amp but had no success.
So, I have several questions, like these:
  • What type of source can I connect in the audio inputs? Too much gain ???
  • Is it better than Mullard 5-20? Or should I forget it and go with 5-20?
  • How the pots connected to 'line in' on EF86 works? Are they like a mixer?
  • The original output transformer was 800 ohms. One was broken. I'm using a spare pair with 4/8 and 16 ohms. How should I modify the feedback loop?
Well, the only thing I can do now is drink a beer ... by the way, I will check the schematic ... may be I draw something wrong ...
More photos here.
Old 8th August 2014, 07:19 AM   #13
jazbo8 is offline jazbo8
jazbo8's Avatar
You have an unique amplifier, imo, you should not modify it to Mullard or anything else, it should be restored (sans the OPT) to the original condition as much as possible. Is there a model number shown on the front plate (on the box containing the EF86)? Also, what are the control functions on the front panel, from left to right? Since the OPT is gone, you are free to re-configure the output to work with modern off-the-shelf one - but it's still going to be a big one though. How much power do you need?
Old 8th August 2014, 11:17 AM   #14
okcrum is offline okcrum  United States
There seem to be some missing connections around V8B on your schematic. I agree with restoring the amp rather than modifying it.
Old 8th August 2014, 02:28 PM   #15
Ketje is offline Ketje  Belgium
Ketje's Avatar
The inputs seems to accept two sources with one vol.cotrol.Nothing in the middle ,one direction for each source.
In the bottom the two inputs have something like a (adjustable) phantom supply.Very sensible, condensor-mike ?
There are some errors in the schematic but make not to much about it,Herman Karton make them too .
I indicated with a red "circle" where I found something wrong.
The use of the two Si-diodes is not very clear.
Mona
Old 8th August 2014, 02:30 PM   #16
Ketje's Avatar
Now here is the schematic with my suposed adjustements.
Mona
Old 8th August 2014, 02:46 PM   #17
I thought about Mullard 5-20 because there are a lot of information out there and the tubes are all the same, as the power transformer. But for this unit I know nothing.
I think it was used as a PA on a cinema or theater. The inputs are microphone, pickup and two source in for audio projector. But I know nothing about this circuit and the quality of the sound.
But as you suggested, I will try to restore to its original condition.
There is a model number but I tried to find any information about them with no success. The model is Philips type 3860/24, serial number 192, 275 watts.
The controls on the front, from left to right, are:
  1. Volume control for output EF86 and connection to ECC83;
  2. Switch from Mic/Pickup Input (down) and line 1 and 2 (up)
  3. Volume control for inputs Mic/Pickup (half for each one)
  4. Treble
  5. Bass
  6. Power On
For power output anything between 50 and 75 watts are welcome. I will probably buy a pair of OT for UL use.
I'm still trying to find reviews for this circuit.
Old 8th August 2014, 02:47 PM   #18
Your are right! Thank you.
Old 8th August 2014, 02:53 PM   #19
Mona
Thank you for your help.
I will make the adjustment. And you are right about the vol. control: one direction for each source, but this is true only for Mic/Pickup (the two source in on the bootom). For EF86, the output is connected to one vol. control.
Old 8th August 2014, 03:03 PM   #20
Mona
Very good, thank you a lot.
I will turn on one monoblock e measure the voltage and check with your values. They seem to be very close.
The feedback resistor is 33k (330k was wrong as the r22 that is 68 ohms/50w). But it was projected for 800 ohms at the output of OT. Now, which value should I use?
About the input of EF86, what kind of source can I connect? I tried a CD input with a passive preamp but the gain is too high. Is there any mod that I can do to get better results?
About diodes, I included them as suggested on post #3.
I'm now working on the schematic!
Need Help - Monoblock Power Amplifier EL 34Hide this!Advertise here!
EL-34 to 6P3S-E Laila2 Tubes / Valves 21 1st November 2010 10:13 PM
EL-34 and 100k pot podboy Tubes / Valves 1 27th June 2007 12:49 AM
WTB:OT for el 34 35 watt tube amplifier sma Tubes / Valves 6 29th December 2005 04:19 PM
Power Amplifier With EL 34 marinbnm Tubes / Valves 4 3rd November 2004 03:39 PM
el-34 suggestion mezon Tubes / Valves 7 10th April 2003 10:28 PM
Copyright ©1999-2017 diyAudio
