CV2799 (Mullard) QQV04-20 parallel single-ended audio amplifier
Old 27th July 2013, 09:47 AM   #11
TURING is offline TURING  China
Originally Posted by farhun View Post
TURING, is the OPT you used, with 3.5K primary really optimum, or have you tried any other transformer?
CV2799 I do not have full power output, but in accordance with 832 (FU32) adjusted, according to the performance curve, should be used in parallel after 3-5k output transformer. Select 3.5k output transformer, the optimum value should be.
Old 27th July 2013, 10:17 AM   #12
Shoog is offline Shoog
Shoog's Avatar
Surely these tubes are a better candidate for a Push Pull amp. It seems a bit of a waste to parallel them.
Shoog
Old 27th July 2013, 04:04 PM   #13
farhun is offline farhun  United States
CV2799 is here http://www.r-type.org/pdfs/cv2799.pdf
Old 27th July 2013, 05:33 PM   #14
Shoog
Agree with you. I also do a push-pull output tube amp. Recently will upload pictures. Push-pull tube amp really better than single-ended. Unashamedly. However, single-ended output otherwise charm, it depends on the preferences of the audience.
Old 5th February 2015, 09:38 PM   #15
blackdod is offline blackdod  Europe
Hello guys
I would like do this amp but only for Headphones (32~600 Ohm). On ebay I saw a similar amp and has a headphone out.
How can I implement a headphone out?
CV2799 (Mullard) QQV04-20 parallel single-ended audio amplifierHide this!Advertise here!
Parallel Single-Ended Questions Sherman Tubes / Valves 13 6th October 2017 07:09 AM
parallel single-ended 12W6 scott17 Tubes / Valves 17 8th September 2017 03:20 PM
Cary Audio CAD300SE Single Ended Amplifier Pair FS GordonW Swap Meet 0 14th September 2012 06:52 PM
Wiring - Audio Note Transformer Parallel Single-Ended 300B xerocomm Tubes / Valves 1 11th May 2010 07:18 PM
Parallel Single Ended Amplifier Design using Acro TO-290s? diamondsouled Tubes / Valves 3 15th October 2009 07:42 PM
