Ultra-Linear vs. Pentode Longevity
Old 24th July 2013, 02:42 AM   #1
BRSHiFi is offline BRSHiFi  United States
Previously known as kingden
Default Ultra-Linear vs. Pentode Longevity
When maximizing tube life, for each of the following tubes, is pentode or UL better? I hear mixed opinions.
-KT120, KT90, KT88
-EL34, 6L6, 6V6, EL84
Old 24th July 2013, 03:00 AM   #2
gingertube is offline gingertube  Australia
Given the same operating voltages and idle currents Ultralinear will allways give better tube longevity. When signal is applied, as anode current increases (on the appropriate half cycle), that is, as the anode is pulled lower in voltage then the screen voltage will drop too, thus limiting the rise in screen current.
In Pentode Mode there is no mechanism limiting screen current. You have to do that yourself by adding screen resistors. Big screen resistors give noticable audio compression which can sound OK for guitar but is NOT what you want for HiFi.
So for HiFi you want screen resistors (mounted hard up against the tube socket screen pin) to give you a grid stop function but you want only as much resistance as required
to suppress any parasitic oscillation. If you need more to protect the tube then you are operating at too high a B+ voltage and/or too high an idle current and you should fix that instead.
Of the tubes listed I have run KT88, EL34, 6V6 and EL84 in HiFi Amps and prefer Ultralinear Mode to Pentode Mode for all of those. I have not tried the others.
I've run 6L6, EL34, 6V6 and EL84 in guitar amps. Only my 6V6 amp had switchable UL/Pentode Mode and I found (for guitar) I preferred Pentode Mode.
Cheers.
Ian
Old 24th July 2013, 03:22 AM   #3
How long would you expect a set (quad/pair) of new production KT88/KT90/KT120's to last in ultra-linear mode using regular capacitor coupling from a phase splitter? There is 47k ohms worth of resistance through the bias circuit from the control grid to ground. The B+ in ultra-linear is 550 volts.
Old 24th July 2013, 03:48 AM   #4
As long as you have a max Rg1 of 47K for EACH TUBE then I would expect a minimum of 5 years life. Most failures I've seen have been due to thermal run away from too high an Rg1 value. That is why on all new designe I use cathode followers or mosfet source followers, one per output tube, direct coupled to the output tube grid and with the bias voltage then applied the follower grid/gate.
Getting Rg1 to a suitable low value is the most important thing you can do for tube reliability. Because the Rg1 is also a load on the Phase Inverter (unless you use a mosfet source follower or cathode follower buffer) it is also the one thing which is most often gotten wrong.
If you do a search you may find a few posts with schematic traces I did on an ARANOV LS9100 which is a quad 6550C in Ultralinear, 100 Ohm screen resistors, +530V. It had suffered a thermal run away, the usual problem of too high an Rg1 value. I selected Winged C Svetlana 6550C for match AND low grid current too try and make that more reliable .
Ian
Old 24th July 2013, 03:55 AM   #5
First round of KT88's, I had one arc after about 1.5 or so years. This was the revision before I applied the low Rg1 resistors. Was the arc in any way due to a thermal runaway?
Old 24th July 2013, 04:18 AM   #6
multi is online now multi  Australia
Default GEC 4 x kt88
Gingertube
I have made several amplifiers using the GEC multiple pair KT88 circuit using 4 Tubes. Attached.
A member on another thread was very critical of this circuit due to the Cathode resistors on the 6SN7ís being 47k he claims it should only be 15k and the 47K grid resistors for the KT88ís.Later circuits used 39K.
I wondered what values you used on your cathode followers to drive KT88ís? Do you have a circuit?
I found the output tubes 6550ís on this amp last a long time and due to the mains running high in West Australia at times the plate voltage on the 6550's was 580 volts.
Phil
Old 24th July 2013, 04:31 AM   #7
directdriver is offline directdriver  United States
directdriver's Avatar
550v B+ might be too high for ultralinear operation in a KT88. I know typical 6550 wouldn't like it. In ultralinear mode the plate and the screen is pretty much getting the same voltage so when that voltage exceeds the screen rating in the tube manual, expect shortened life. In pentode operation you can always choose a lower voltage point for the screen independent of the plate voltage and that would always help tube life. High screen voltage is one of the major causes of short tube life. If you must use ultralinear then choose a voltage point that's safe for both the plate AND the screen. There's a reason many vintage commercial tube amps using EL34 or 6550/KT88, do not exceed 450V. (Marantz runs EL34 at 425v in UL.) If you must milk power then use high plate voltage and lower screen voltage, preferably regulated.
The sonic difference or preference between pentode and ultralinear is another topic.
Old 24th July 2013, 04:34 AM   #8
If you look at old KT88 data sheets you will get the big clue.
http://www.triodeel.com/kt88p1.gif
Cathode Bias:
Max Rg1 with Pa <= 35W 470K
Max Rg1 with Pa >35W (42 W max) = 270K
Fixed Bias:
Max Rg1 with Pa <= 35W = 220K
Max Rg1 with Pa > 35W (max 42W) = 100K
So for a parallel pair of KT88 you want Rg1 to be less than 100K||100K = 50K IF you are biasing them at maximum idle power.
If you drop the idle current so that you are idling at 35W or less the max Rg1 can be 220K || 200K = 110K max.
For 5 tubes on each side of the push pull that would mean 220K/5 = 44K max if baising tubes at <=35W. 47K is a little above that so what I would be suggesting is that for a single 47K with 5 tubes then you would want to bias each tube at about 32 Watts
Guitar Amp Guys (the most abused Rg1 values known to man) sort of know this, or at least they know that they should bias their amps at not more than 70% of maximum anode dissipation rating. That is, they know to do this but probably don't understand why.
Was the arc due to thermal runaway? - YES almost certainly.
Ian
Old 24th July 2013, 04:35 AM   #9
artosalo is offline artosalo  Finland
artosalo's Avatar
Originally Posted by gingertube View Post
Given the same operating voltages and idle currents Ultralinear will allways give better tube longevity. When signal is applied, as anode current increases (on the appropriate half cycle), that is, as the anode is pulled lower in voltage then the screen voltage will drop too, thus limiting the rise in screen current....
Cheers.
Ian
This may be possible assuming the condition you mentioned (same voltage/idle current).
I have noticed when compared UL / pentode circuits that optimum linearity in UL circuit requires higher idle current than in pentode.
So in practice the case about longevity is not that straightforward.
Old 24th July 2013, 05:09 AM   #10
Right now I am running KT90 quads in my amplifiers. The current revision has 100k ohm resistors R17, R19, R22, and R100. In the third revision I plan on swapping those for 22k. A maximum of 5K + 18k (through the bias network) + 22k yields 45k ohms. Should those net to ground equal 45k or just the R17, R19, R22, and R100?
As it stands the circuit produces very low distortion (< 0.3% at 1k at 138 watts) with a continuous sine wave into an 8 ohm resistive dummy load. Should I lower B+? KT88 screens can take up to 600 volts and KT90, higher. The objective for future revisions is to ensure long tube life to avoid breaking the bank of maintenance costs.
Ultra-Linear vs. Pentode LongevityHide this!Advertise here!
ultra linear aikido with linearizing pentode Jehan Tubes / Valves 0 12th October 2012 01:06 AM
Longevity of output tubes in triode vs pentode john dozier Tubes / Valves 4 14th March 2011 11:15 AM
Ultra-Linear Zen flg Pass Labs 9 12th December 2007 05:01 PM
EL84 in ultra-linear mode cs Tubes / Valves 8 21st September 2006 03:50 PM
An Ultra -linear question fscarpa58 Tubes / Valves 5 29th July 2004 12:28 PM
