2 amp simulation/dummy load for transformer
Old 21st July 2013, 03:52 AM   #1
lordearl is offline lordearl  Australia
Default 2 amp simulation/dummy load for transformer
I've got a 30VA rated transformer for a 12.6v filament circuit and need about 1.7 amps, is anyone able to inform me how best to set up a test circuit to ensure the 12.6v (post rectification) won't drop below the 10% allowable for tube filaments? 30va should give 2.4 amps (using a low voltage drop regulator etc)....
Old 21st July 2013, 04:37 AM   #2
BZed is offline BZed  United States
What's wrong with a 7.5 ohm 50 watt Dale or ohmite resistor?
Old 22nd July 2013, 04:08 PM   #3
DF96 is online now DF96  England
Rectifying and smoothing a transformer output immediately means that you get significantly less DC watts than the VA rating, especially for constant load duty like a heater circuit. I don't carry the exact figures in my head, but assume a 30VA transformer will provide about 10-15W of constant DC.
Old 22nd July 2013, 04:13 PM   #4
tomchr is offline tomchr  Canada
tomchr's Avatar
You can set it up in spice or PSUD II. Have a look at the RMS current in the secondary for a given load. I suspect that under the conditions you mention, you'll exceed the transformer rating of 2.4 A.
~Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
2 amp simulation/dummy load for transformerHide this!Advertise here!
Tube Amp Dummy Load questions exnomine Instruments and Amps 24 3rd May 2018 09:14 AM
Tube Guitar amp, dummy load - Advice needed! Benjamino Instruments and Amps 20 7th May 2014 01:27 PM
Dummy load with output to power amp acio Analog Line Level 5 13th March 2010 06:37 PM
Configurable Dummy Resistor Load Box for Amp design/repair knausz Equipment & Tools 4 2nd February 2010 11:53 PM
Dummy load to reduce output of 300w/ch amp? steve71 Solid State 18 1st January 2008 11:07 PM
