Optimal Operating Point for E280F Driver for 300B Single End Amplifier - diyAudio
Old 20th July 2013, 07:10 PM   #1
Wink Optimal Operating Point for E280F Driver for 300B Single End Amplifier
Hello , I need help to Know which is the optimal operating point for a E280F driver for 300B Amplifier .. thanks a lot
Old 21st July 2013, 12:55 AM   #2
tomchr is offline tomchr  Canada
tomchr's Avatar
To drive a 300B, you'll need a driver that can provide 200 Vpp of swing, cleanly. Whether the E280F is a good candidate for this, I don't know. But I'm sure if you look at the datasheet, you should be able to figure out whether this tube can provide that much swing.
Driving a 300B is no simple task. I've only found a few tubes that are up for the task - JCC99, 6N6P, 12BH7A, and ECC88. But I haven't looked at every tube known to man and in my circuit, I needed a tube that had high gm and reasonable mu (20~30), which imposed some restrictions on the tube selection as well.
~Tom
Modulus-86: 40W/8Ω @ 0.000061% THD. HP-1: 3W/20Ω, 450mW/300Ω @ 0.000032% THD. DG300B and Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 21st July 2013, 01:42 PM   #3
azazello's Avatar
U plate 160-180V and I plate 16-18 ma.
Old 21st July 2013, 02:18 PM   #4
thanks friends , and is true that d3a is far better for driving 300B ?
Old 21st July 2013, 07:48 PM   #5
euro21 is offline euro21  Hungary
Far better? IMHO it's thing of taste.
In my 300 SE (E280F/D3a, 2V green LED bias, 11mA DN2540 cascode CCS, 220nF CuTF coupler, FET source follower -powerdrive to A2- to 300B, 5K:8 OPT) I tried some tubes.
D3a (Siemens, Valvo, Telefunken) gives more power (up to 10W), dynamic -rock!-, but E280F (Siemens, Telefunken) more refined (only 7W).
Although I listen mostly classical and jazz music.
Old 21st July 2013, 09:00 PM   #6
thanks again, is important that E280F work between 11ma and 14ma plate current aprox ?
Old 22nd July 2013, 09:43 AM   #7
azazello's Avatar
More 16 ma.
Old 22nd July 2013, 11:38 AM   #8
thanks azazello !!!!!
Old 22nd July 2013, 04:08 PM   #9
tomchr's Avatar
d3A in triode is nice as well.
~Tom
Old 22nd July 2013, 08:37 PM   #10
thanks a lot Tom
E280F Triode mode operating point frankmalz Tubes / Valves 2 20th July 2013 09:50 PM
Front End DC Operating Point Current Magnitudes acoustixman Solid State 1 6th December 2011 11:10 AM
6SL7 operating point in FCUPS 300b amp mattattnet DIY HiFi Supply 3 30th March 2011 12:21 AM
300B preamp - best operating point mkollmaier Tubes / Valves 8 20th September 2010 08:14 PM
Optimal operating point for 7N7/6SN7? pftrvlr Tubes / Valves 5 16th December 2008 04:43 PM
Copyright 1999-2017 diyAudio
