Life Expectancy of DHT's
Old 18th July 2013, 07:35 AM   #1
rcollege is offline rcollege  United States
Default Life Expectancy of DHT's
How does the life of DHT's compare with IDHT's.
Anyway, I wired up a simple SE preamp using a 1J5 battery pentode in triode mode...blows the doors off of IDHT tubes I've tried...(including a 7N7 - loctite version of the 6SN7 and 6Y6GT) in terms of clean sound, tighter bass and silent background.
I come across these odd tubes at a local electrical surplus store. I paid $4.50 for the 1J5's and just scored 6Y6GT's for $2.80 ea. So I try them out and play with different types and sound before I go to more expensive tubes.
I'm thinking of other standard tubes such as the 26...but as our entertainment center audio system, I'm not sure if they would last.
As far as IDHT, I'm even thinking of trying some 6L6 in triode for a line level preamp...even though its major overkill. I can get a good deal and easily found locally. So as long as it won't be too much current for the ST-35. I hear good things as far as sound. I prefer the sound of larger tubes...
Life Expectancy of DHT'sHide this!Advertise here!
HQ-DHT (All tube DHT amli) 26-45-2A3 quanghao Tubes / Valves 44 20th January 2013 09:58 AM
Material life-expectancy chairforce Full Range 14 25th June 2010 10:52 PM
Life expectancy for used electrolytic caps clm811 Solid State 24 6th March 2010 08:07 PM
tube rectifier life expectancy Raj1 Tubes / Valves 12 20th June 2004 05:40 PM
Opinion upon amp life expectancy at 5 hours/day? (theres a catch) Layberinthius Tubes / Valves 20 17th January 2004 05:02 PM
