How do I repair my Tube Amp? - diyAudio
Old 17th July 2013, 07:26 AM   #1
hydrovac's Avatar
Default How do I repair my Tube Amp?
Need help in fixing my Tube amp.
Hello everyone,
I really need help. A month ago my cayin MT12A tube amps power transformer failed and stopped functioning.
I tried contacting the manufacturer for support but there is no response. Does anyone have knowledge about these amps. Schematics or at least the transformers secondary voltages so that I can get it wounded.
Any assistance in this regard would be much appreciated. Thanks in advance.
Krishna
For some people, it's a part of life. For others it's irrelevant.
The mysteries of neurology and how our individual brains function.
Old 17th July 2013, 08:18 AM   #2
I strongly advise that you thouroughly examine that amplifiers circuit for faults and short circuits before you plug in a new transformer, you might risc that you just damage the new one too if you do not locate the source of the first failure.
Old 17th July 2013, 09:24 AM   #3
M Gregg is offline M Gregg  England
How do you know,
That the transformer is damaged?
What tests have you done?
M. Gregg
Old 18th July 2013, 12:06 PM   #4
hydrovac's Avatar
Hey guys,
Here is the link to the product I am referring to. See if you can make out anything from that.
Zhuhai Spark Electronic Equipment Co.,LTD,-
Old 18th July 2013, 12:59 PM   #5
This might sound stupid but,
How do you know the power Transformer is damaged? Have you checked the mains supply to the primary? and the secondary output volts with a volt meter?
If not have you checked continuity and resistance of the windings?
Do you have any power at all to the primary of the power Tx?
What I'm trying to say is HAVE YOU CHECKED THE FUSE...sigh...lol
This looks interesting..
http://www.audiokarma.org/forums/sho....php?p=6951834
Stop and think! Listen to the questions what have you done to prove the Tx is damaged..you keep saying you want to rewind it.
If we know its damaged then OK it needs a replacement or repair.
M. Gregg
Old 19th July 2013, 07:19 AM   #6
hydrovac's Avatar
OK,
I disconnected and opened up the transformer, and checked the resistances of prim and sec windings. Primary is showing shorted. (photo)
1 sec shows 36ohms
2 sec 2 ohms
3 sec nothing (open)
What other tests should I conduct, to know the condition of the Xformer.
IMG_4589 by hydrovac, on Flickr
IMG_4590 by hydrovac, on Flickr
IMG_4591 by hydrovac, on Flickr
IMG_4599 by hydrovac, on Flickr
IMG_4600 by hydrovac, on Flickr
Old 19th July 2013, 11:20 AM   #7
Alastair E's Avatar
Primarys always show a very low resistance in a test like this!
I would be surprised if the primary was more than say, 15 ohms!
Any fuses blown?
What voltages do you get if primary connected to supply and secondary voltages tested?
--Take care with these tests as mains as well as secondary voltages are capable of Killing Easily!
Das Beste Oder Nichts
Old 19th July 2013, 11:40 AM   #8
JonSnell Electronic's Avatar
A DVM is not the best way of measuring the DC resistance of a primary or secondary. Use a moving coil AVO 8 or similar. The resistance will show very low and as the flux builds get higher. If no flux builds, the transformer has shorted turns.
Old 19th July 2013, 01:50 PM   #9
Alastair E's Avatar
Hmm--Think you have that the wrong way round!
During this test with something like Avo-8--Which the O/P may not have access to as he isnt in the UK.......
The apparent 'resistance' would appear High, Then will fall as the flux builds.....
--This effect may Not be apparent with some transformers though IME.
Either way--once settled, the DC steady-state resistance will only be a handful of ohms of the Primary....
Old 19th July 2013, 02:00 PM   #10
My mistake, it has been a while.
Yes, the resistance reduces as the field builds. Any moving coil meter will work. I used an AVO as an example.
Tube Amp Repair - SE Michigan kach22i Tubes / Valves 0 23rd March 2012 07:34 PM
Tube Amp (Rivera guitar amp) repair gone wrong ems71 Instruments and Amps 16 24th February 2012 06:09 PM
Tube amp repair hwong Full Range 2 7th November 2008 04:20 AM
Tube amp repair hwong Tubes / Valves 6 7th November 2008 04:16 AM
vintage tube amp repair help adason Tubes / Valves 25 10th December 2006 10:48 PM
Copyright 1999-2017 diyAudio
