diyAudio Sponsor
Old 9th December 2003, 11:36 AM   #1
Default 12B4A tube amplifier with output transformers
Hi
I have looked thru the forum trying to find a PP 12B4A amplifier that uses output transformers. NO, I do not want the transformerless version that has been floating on the web.
Please post any interesting ideas as I have heard the 12B4A is a distant cousin of the 2A3 tube.
Joe
Old 9th December 2003, 12:31 PM   #2
Fuling is offline Fuling  Sweden
12B4A, my favourite pet!!
Unfortunately I´ve never tried them in a PP amp but I´m sure they´ll perform fine. Give them nice transformers and driver stages, they deserve it
And by the way, be sure to mount them with the cathodes visible, since they glow quite nice.
Old 9th December 2003, 01:44 PM   #3
Brett's Avatar
Default Re: 12B4A tube amplifier with output transformers
I've never seen one
OTTOMH idea
OPT = 10ka-a
B+ = 200V
Ia = 28mA/tube
Rk = 420R // 100uF common to both tubes
Vg = - 21.5V
Driver is a diff or paraphase ECC99 with Hammond 156C as loads at 150Va and 15mA/tube.
PSUD a decent power supply.
Old 11th December 2003, 10:46 AM   #4
316a is offline 316a  England
316a's Avatar
Default Re: Re: 12B4A tube amplifier with output transformers
Originally posted by Brett
I've never seen one
OTTOMH idea
OPT = 10ka-a
B+ = 200V
Ia = 28mA/tube
Vg = - 21.5V
Op point looks good . I would use a 30VA 115+115/6+6 mains toroid as an output , secondaries paralleled to get a prototype going . 12B4a vary electrically , better to buy a bunch and match them up for PP , better still add variable grid bias and balance meters . A reference could be this schematic which uses a similar valve (beefier version:6CK4)
http://tinpan.fortunecity.com/saints...er/6ck4-pp.gif
Hope this helps
316a
Tube amp transformers 4 pwr 4 output 1 choke (used) Westerp Swap Meet 0 18th May 2009 07:37 PM
Tube Output Transformers in NY pedroraiser Swap Meet 3 9th September 2008 02:09 AM
amplifier for unknown output transformers? tonskulus Tubes / Valves 20 9th December 2007 11:36 AM
Best price for tube output and power transformers ? mario2005 Tubes / Valves 1 31st July 2006 07:12 AM
New output transformers for Quicksilver amplifier Original Burnedfingers Tubes / Valves 13 20th February 2003 09:32 PM
Page generated in 0.07913 seconds (75.57% PHP - 24.43% MySQL) with 10 queries
