Tube amp to drive 4 ohm headphones? - Page 3 - diyAudio
Old 23rd July 2013, 06:55 PM   #21
I would just get really good headphones.
and put the tweeters in a box with a pair of 6's
Old 28th July 2013, 10:07 AM   #22
regal is offline regal  United States
Originally Posted by ChrisA View Post
At 4 ohms he is going to be using an output transformer. (or as you say solid state.) A tube based OTL is just a "circus stunt". Seriously I don't know what else I'd call a pair of EL34 (or like) tubes driving headphones. .
Some headphones require 2-6 watts, do the calculations and you will find that driving 70db/mW 50 ohm headphones require a tube even more powerful than an EL34. Even audionote as a PSE EL34 headphone amp kit, no circus experiement basic physics.
Anyway for the OP with 4 ohm highly sensitive phone you definaely don't want an OTL. Your biggest issue will be noise. A good headphone amp has zero hum or noise, that's right against the ear at listening level playing a silence track. true black background is your goal. Several of us have built SSHV Spud SETs to good results, that's the direction I would pursue.
Bridging two 300W in 8 ohm amplifier to drive 1200W in 8 ohm rhythmsandy Solid State 3 2nd December 2012 05:47 AM
Amp for 16 ohm headphones (MDR-EX71SL)? AudioLapDance Solid State 3 7th December 2011 03:20 PM
single tube to drive 300ohm headphones sunrise Tubes / Valves 26 10th March 2009 12:09 PM
Can the Golden Tube Audio SE-40 SE drive 16 ohm woofers? nelsondog Everything Else 1 11th November 2007 05:00 PM
Converting a yarland amp to drive headphones arvin Tubes / Valves 0 27th February 2007 01:29 PM
Copyright 1999-2017 diyAudio
