SS phase splitters?
SS phase splitters?
Old 10th July 2013, 09:30 PM   #11
ingenieus is offline ingenieus  South Africa
Originally Posted by Eli Duttman View Post
Correct operation of a tube, with few exceptions, requires the control grid be negative with respect to the cathode.
Thanks for that. The light suddenly came on and it nearly blinded me. I should read on tubes some more.
Old 11th July 2013, 11:38 AM   #12
I have run a simulation of the circuit with MOSFETs in place of the tubes. It works, but the output is only 5Vpp, so some more work is needed. Since the OP has reacted yet, I will leave it on the back burner.
Old 11th July 2013, 03:36 PM   #13
kenpeter is offline kenpeter  United States
My 2, Pointlessly equal impedance hybrid concertina with Mu/2 gains...
Old 11th July 2013, 04:14 PM   #14
rsumperl is offline rsumperl  United States
rsumperl's Avatar
SS phase splitters?
Good morning,
I'd like to try the above circuit. Any guesses on how much swing? I'm building a sweep tube amp that will probably have 40-45v of bias.
Thanks,
Ray
A great pleasure in life is doing what people say can't be done.
Old 11th July 2013, 05:01 PM   #15
M Gregg is offline M Gregg  England
Thanks for the input so far,
Great ideas and circuits.
I was wondering how easy/hard it would be to implement, (reduce space) with some of the more complex splitters. Nice to see other examples.
Theoretically I guess you could build a whole tube circuit with FETS I wonder if anyone ever has and what it sounded like (Off topic) FET with OP Tx.
Back to phase splitters the small 6V6 is interesting.
M. Gregg
Old 11th July 2013, 05:46 PM   #16
mos57 is offline mos57  Italy
mos57's Avatar
Those days i have presented a new type of phase splitter. There are also version specified for tube circuits.
Have a look at this thread:
http://www.diyaudio.com/forums/solid...-inverter.html
Francesco
Old 12th July 2013, 09:55 AM   #17
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
SS phase splitters?
Originally Posted by ingenieus View Post
I can read Dutch and Flemish, but my French is non-existent.
try with google translator
Here are the actual links.
wow, a wimpy BS107
btw, would a simple SS 'phase splitter' handle multiple parallel output tubes better than if a tube
Old 12th July 2013, 01:41 PM   #18
Originally Posted by tinitus View Post
wow, a wimpy BS107
The Velleman K4000 comes to mind with a 12AX7 in concertina driving 4 EL34 per channel. You may have a point!
M. Gregg
Old 12th July 2013, 02:58 PM   #19
SS phase splitters?
not so sure
driving capacitance also seems problematic with solid state designs
maybe its all the same, a Murphy's Law
anyway, what is the reasoning for using solid state devices ?
gosh ! I only know the difference of tubes and SS by the looks
Old 12th July 2013, 03:01 PM   #20
P
SS phase splitters?Hide this!Advertise here!
PP splitters again Bill*B Tubes / Valves 16 17th October 2006 12:04 PM
Phase Splitters teodorom Tubes / Valves 21 5th July 2005 10:10 AM
Using microphone transformers as phase splitters . Shoog Tubes / Valves 8 21st December 2004 05:30 PM
Anyone use ICs as input phase splitters for tube equipment zobsky Tubes / Valves 5 20th March 2004 12:02 AM
Phase splitters: Constant current sources BlackUnikorn Tubes / Valves 10 25th November 2003 02:44 AM
