6N7...this configuration work ?
Old 5th July 2013, 09:17 PM   #1
aldovan is offline aldovan  Brazil
Default 6N7...this configuration work ?
Friends
I want use the two sections of a 6N7 as voltage amplifier in cascade.
This configuration is possible ? Work without problem?
Thanks,
Aldovan
Old 5th July 2013, 09:21 PM   #2
Shoog is offline Shoog
Shoog's Avatar
No grid leak on either section. No it won't work as drawn.
Shoog
Old 5th July 2013, 09:30 PM   #3
Default Sorry I forget...
Shoog
OK, AND NOW ?
Old 5th July 2013, 09:42 PM   #4
ilimzn is offline ilimzn  Croatia
...And it is in danger of becoming a Schmitt trigger circuit. In this case the common cathode is actually positive feedback. Although the LED has a very low impedance compared to the cathodes, looking at it on a dB scale shows a problem - this amplifier will have a small hysteresis WRT input signal. I.e. it will be non-linear in a ost unwelcome fashion. If you are building a stereo amp, use one 6N7 as the first stage and another as the second stage, do not use one for both stages.
Old 5th July 2013, 09:57 PM   #5
Default Ok, and now ?
Ok, and now, work ?
Old 5th July 2013, 10:03 PM   #6
Default new variation
Originally Posted by aldovan View Post
Ok, and now, work ?
Attachment 358343
And now ?
Old 5th July 2013, 10:12 PM   #7
Merlinb is offline Merlinb  United Kingdom
Merlinb's Avatar
OK, AND NOW ?
Attachment 358342
Yes that will work. You don't need to worry about Schmitt trigger action with only an LED in the cathode circuit; it's impedance is negligible.
CCDA Noval Stereo PCB
Old 5th July 2013, 10:17 PM   #8
But I need the capacitor in parallel or not ?
Old 5th July 2013, 10:21 PM   #9
Merlinb's Avatar
You don't *need* one, but you can try it if you like.
Also, I think you meant to use 47k anode resistors and not 4.7k.
Old 5th July 2013, 10:42 PM   #10
No, I want driver a power triode.
Now the circuit is ok ?
I will use 600V in the plates and the catode current is 40mA,
The tube is replaced by RK34.
6N7...this configuration work ?Hide this!Advertise here!
45 amp with 6N7 crazyfrog Tubes / Valves 63 9th June 2013 12:55 AM
6n7/2a3 kianbach Tubes / Valves 14 4th January 2011 01:25 AM
6N7 PP amplifier eta_beta_60 Tubes / Valves 7 24th April 2008 06:45 PM
Will this cable configuration work? Hybrid fourdoor Multi-Way 9 22nd June 2004 10:46 AM
Is 6N1P = 6N7 = ECC31 ddriveman Tubes / Valves 1 18th March 2004 01:09 PM
Copyright ©1999-2017 diyAudio
