...And it is in danger of becoming a Schmitt trigger circuit. In this case the common cathode is actually positive feedback. Although the LED has a very low impedance compared to the cathodes, looking at it on a dB scale shows a problem - this amplifier will have a small hysteresis WRT input signal. I.e. it will be non-linear in a ost unwelcome fashion. If you are building a stereo amp, use one 6N7 as the first stage and another as the second stage, do not use one for both stages.
Ok, and now ?
Ok, and now, work ?
Ok, and now, work ?
Yes that will work. You don't need to worry about Schmitt trigger action with only an LED in the cathode circuit; it's impedance is negligible.
CCDA Noval Stereo PCB
But I need the capacitor in parallel or not ?
You don't *need* one, but you can try it if you like.
Also, I think you meant to use 47k anode resistors and not 4.7k.
Hi!
As has been mentioned before: 4,7k is way to low as a plate load resistor for the 6N7. This would give big distortion and very little gain.
You should share more details what you intend to do then you can get better advice.
How much gain do you need?
Which tube do you intend to drive?
As much as I like the 6N7 I think you will be better of with another tube. I only use it with parallel sections. The individual sections have a plate resistance of over 20k and bias current of 3mA. That's ot much to drive anything
Best regards
Thomas
Best regards
Thomas
- Tubes / Valves
- 6N7...this configuration work ?
