RIAA Active EQ
RIAA Active EQ
Old 5th July 2013, 06:14 PM   #1
BRSHiFi is offline BRSHiFi  United States
Previously known as kingden
Default RIAA Active EQ
What is the best way to compute the values for the feedback network for this active RIAA circuit?
I have been attempting trial and error with a few different configurations but am getting nowhere.
I already made a passive stage which was much easier to manage.
Attached is a Tina file along with a schematic screen.
Old 5th July 2013, 06:17 PM   #2
On Hiatus
SY's Avatar
RIAA Active EQ
That cathode follower is going to be very unhappy trying to drive the RIAA network at high frequencies!
The basic equations for calculating feedback EQ were published by Lipshitz back in the '70s and that article is likely floating around the Web somewhere. The 12AX7 is a very poor CF anyway, so you ought to consider a better choice (high gm, higher current). Loop gain for an SP6/SP3/Marantz type circuit is marginal, overload characteristics are somewhat dreadful.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 5th July 2013, 07:27 PM   #3
HollowState is offline HollowState  United States
HollowState's Avatar
If you really want to use 12AX7's in that configuration, or you simply must diy, why not avoid the mental masturbation of all that math and just copy the Marantz 7, McIntosh C22, Audio Research SP3 or several others that did that long ago with fair results. And put the feedback point right to the cathode instead of trying to drive a 39 ohm load. Also, does your inverse RIAA network input match the output impedance of your signal generator? If not you'll get response errors.
There cannot, and never will be, any progress in society, vis-a-vis racism, so long as the concept of celebrating Diversity -- in it's current, politically-correct, deliberate, punitively extractive form -- continues.
Old 5th July 2013, 08:10 PM   #4
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
Not computing the values at all. That design is so horrible it's not worth pursuing.
A) The 12AX7A makes an absolutely horrible cathode follower: the current supply capability is severely lacking due to the ENNNNNNORMOUS plate resistance of the type (90K nominal). No way will it be able to drive a 39R load.
B) As if the plate resistance weren't high enough already, the unbypassed cathode resistors will drive it up even higher. That will likely make for even worse distortion. 12AX7s need very light plate loading if they are to sound good, and without either active plate loads, or enough DC rail for really big passive loads, they don't sound so good. There are way too many designs out there with 12AX7s that load the plate excessively. This is why there are so many complaints about how bad it sounds. (Small signal pentodes would often be a better choice and would sound better.)
If you're gonna pursue a design that involves active RIAA compensation, best to implement it as a glass op-amp: differential front end -> VAS -> Lo-Z buffer. Then connect the RIAA network between the output and the inverting input side of the differential.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 6th July 2013, 02:46 AM   #5
I cleaned the circuit up.
The Audio Research and other designs look like they have drive impedance issues too.
I raised the impedance to 1MEG on a diff amp. I am messing with values again and nothing seems to respond well in this configuration. Do you have to scale the components based upon that 1MEG resistor?
Old 6th July 2013, 02:51 AM   #6
On Hiatus
SY's Avatar
RIAA Active EQ
Noisy and won't even vaguely conform to RIAA. I won't bother to mention the use of 12AX7 as a cathode follower again... If you scale the components for the 1M resistor, you'll end up with bizarrely high values which can't actually be built and would be hideously noisy if they were.
Have you worked your way through the phono stage design portion of "Valve Amplifiers"? If not, I think it would be worth your while. You're trying to pull off a difficult design and you need a better grasp of the basics to make your life easier. And read the Lipshitz paper!
Old 6th July 2013, 02:23 PM   #7
roline is offline roline  United States
roline's Avatar
Check out the groovewatt, a proven design.....
SO many tubes, SO little time!!!
RIAA Active EQHide this!Advertise here!
Active RIAA Eq for tubes- Brian Clark's article jackinnj Tubes / Valves 2 31st October 2016 06:25 PM
Variability of RIAA eq with tube characteristics? leadbelly Tubes / Valves 21 15th April 2008 06:29 PM
OK to use .wav files with RIAA EQ reversed to test phonostage? LowRedMoon Analog Line Level 8 20th November 2006 05:13 PM
Passive EQ to active EQ Nuuk Multi-Way 13 24th May 2004 07:59 AM
New web page for active RIAA EQ design andy_c Analogue Source 1 15th February 2004 02:01 AM
