Old 22nd December 2003, 10:10 AM   #21
Asen is offline Asen  Bulgaria
Send a message via MSN to Asen
You can find more info about my DIY project here:
Tube pre-amp
Old 22nd December 2003, 09:14 PM   #22
JBasham is offline JBasham  United States
Have you tried using a 5751 instead of a 12AX7?
It's usually a drop-in substitute and it has less gain.
Also many of my friends and I prefer the sound of the 5751 to the sound of the 12AX7. It ususally sounds less "fuzzy" or "muddy."
The only true thing in audio is what you hear with your own ears.
Old 22nd December 2003, 10:50 PM   #23
OK, I took a picture for you...
Old 23rd December 2003, 12:18 AM   #24
diyAudio Senior Member
fdegrove's Avatar
Looks nice, Asen.
Instead of using the resistive voltage divider at the input you could try some degenerative feedback by removing the decoupling cap across the cathode resistor if Zo is not crucial.
Also, why do you have a 1M and 47K R in // at the output?
Frank
Old 23rd December 2003, 02:19 AM   #25
ALBQ is offline ALBQ  United States
Default 12AX7 Pictures
Asen,
Very Nice - also, good job on the internal wiring. Thank you for for taking time to post the pictures. I will need to get a few pictures off on my latest preamp project as it progresses. Thank you and nice work.
ALBQ
FYI - link to my webpage - need updating with latest projects
http://mywebpages.comcast.net/gilles...-MainPage.html
Old 23rd December 2003, 01:24 PM   #26
Thank you all for the comments!
fdegrove,
I tried it without cathode caps but I didn't like the results. Also I don't think the input voltage divider is quite a problem. It is the same thing to have a 250k pot and to turn the volume just a little. The resistor gives me more possibilities to play around with the volume control.
Old 23rd December 2003, 05:55 PM   #27
The 47k at the output is just a load resistor I put for simulation purposes. It doesn't exist in reality. There's 1M resistor only.
ALBQ, nice webpage. Your amps look impresive.
12ax7 srpp dac output Klimon Tubes / Valves 26 30th April 2010 12:59 AM
Lowering Gain on an Aikido Preamp SRMcGee Tubes / Valves 12 11th March 2007 08:49 PM
high gain 12ax7 preamp from scratch? fingerwizards7 Tubes / Valves 2 30th December 2006 05:56 PM
lowering gain on Aleph 3 hancock Pass Labs 4 21st December 2005 05:11 PM
Is There Any Downside to Lowering Gain? Cappy Chip Amps 5 2nd September 2004 07:08 AM
Page generated in 0.11411 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1999-2013 diyAudio
