Substitute 6AQ8 for my 6CG7's - diyAudio
Old 18th June 2013, 10:12 PM   #1
Einric is offline Einric  United States
Einric's Avatar
Default Substitute 6AQ8 for my 6CG7's
I need about 6-9db more gain in my Aikido.
Would a 6AQ8 be a suitable front end substitute?
There is a matched & balanced quad of NOS Tungsram 6AQ8's on E-Bay for $40.
Then I would have a backup set of each.
I'd run the 6AQ8's in front with the 6CG7 follower.
Old 19th June 2013, 08:10 AM   #2
DF96 is offline DF96  England
6AQ8/ECC85 would give you 10-12dB more gain. You might need to adjust the cathode resistors to get the bias right.
Unusual request - most people find the Aikido has too much gain!
Old 19th June 2013, 09:56 AM   #3
TonyTecson's Avatar
i switch to 6r-rh2 when i wanted more gain, most of the time i go with 6r-rh8/6CG7/6H32
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 19th June 2013, 12:25 PM   #4
Einric's Avatar
I am driving a Pass F4 (-.3db gain) on some pretty low efficiency speakers.
I'm really only looking for about 6db more I think.
I don't want to sacrifice the superb sound I have with my 6CG7's though.
I am running 290V B+ for what that's worth.
Switching to 12V heaters is simple with my Aikido since I'm running my 6.3v heaters in series right now.
Old 19th June 2013, 12:45 PM   #5
6N1P is supposed to sound like a 6CG7, but with more gain (35). Or you can try a 6BQ7, 6DJ8, or 6N23P.
Look on the 9 pin Aikido pdf and it will list a number of tubes and their gains.
http://www.tubecad.com/2006/09/18/Ai...%20A%20PCB.pdf
Old 19th June 2013, 10:36 PM   #6
Einric's Avatar
Yes, I have my manual and I can see the gain levels.
I know what some of my options are but I'm suggestions from personal experience here.
Old 19th June 2013, 10:42 PM   #7
TonyTecson's Avatar
i operated mine at B+ of 300volts...
Old 19th June 2013, 11:14 PM   #8
I have run a number of tubes up front. The one I settled on is 6n1p. A bit more gain than 6CG7 and they simply sound better to me. I have also used 6n23p successfully.
MG
FS: Telefunken ECC85 6AQ8 radiostar Swap Meet 1 9th September 2011 12:36 PM
Lafayette LT-100 and 6AQ8 tubes rickl Tubes / Valves 5 17th April 2008 07:54 PM
6gu7 a sub for 6cg7/6fq7? jarthel Tubes / Valves 5 17th May 2007 07:35 AM
Ppp 6cg7/6sn7 Colt45 Tubes / Valves 4 27th September 2006 10:10 PM
Best bias for 6cg7 rossdt Tubes / Valves 5 22nd July 2006 08:51 PM
Copyright 1999-2017 diyAudio
