bifilar output trans in single ended amp - diyAudio
Old 6th December 2003, 04:08 PM   #1
brsanko is offline brsanko  United States
brsanko's Avatar
Send a message via MSN to brsanko
Default bifilar output trans in single ended amp
I'm curious as to wheather one could use a bifilar output transformer on a single ended amp and just run DC through the second filiment to cancel magnetic flux. And if so where could I find such a transformer. I'm working on the design of my first tube amp. As of now I'm thinking about going with a 12au7 for input/driver and a single ended parallel 2A3 output stage. Any suggestions of comments welcome. Oh yeah where can I get 2A3s. I'm poor so I would probably go with Chinese ones for my first project.
thanx
PASSIONN
Old 7th December 2003, 09:45 AM   #2
Fuling is offline Fuling  Sweden
Iīve been thinking in the same ways many times, but I have never tried it out. One problem might be the fact that there will be a signal voltage present at the cancellation winding too, so I guess the DC has to be supplied through a CCS or a choke.
By the way, havenīt Andrea Ciuffoli done something like this?
A quite regular PP output stage but only one tube is connected to the driver stage, the other tube is only there to balance the DC.
Old 7th December 2003, 10:14 AM   #3
Jax is offline Jax  Sweden
This has been discussed during the years but nobody seems to have had a reliable success. Maybe because the bias current in the output tube varies. My own idea is to use a constant current source feeding a low impedance winding and a servo measuring the bias current in the tube to compensate. I have never tried it though.
One weird idea is to use the secondary winding and AC-couple the speaker. Then use a sand state constant current source to cancel the field in the transformer. Complicated, it would be easier to AC-couple the tube to the transformer and feed the tube through a choke.
Extra windings also cause more leakage inductance, something to think about.
Old 7th December 2003, 11:06 AM   #4
Circlotron's Avatar
This is a good solution because the transformer can then have high inductance and tight coupling for good LF and HF response respectively. Because it now doesn't need an airgap in the core (no dc flowing in it) this is much easier to achieve.
Old 7th December 2003, 11:15 AM   #5
Yes, at least in theory. But as Jax points out there must be some reason why noone does it.
The problem with higher leakage inductance should be lower if the cancellation winding only has a few turns and is fed by a high current instead of being similar to the primary winding.
That high DC current could always be used to heat some tubes
Old 7th December 2003, 11:58 AM   #6
Hey-Hey!!!,
Bi-Filar will take up a lot of room. Not good for parasitic stuff. It will also have a voltage on it that matches the tube. Cpaacitive coupling to this winding will be substantial.
Now, you could just put in another winding, of say a third of the plate winding count, not absolutely a bi-filar one, and pass higher current through it. at the 'one third' count, you'll develop a third of the voltage and require 9x the current to off set the plate's field.
Just because nobody has tried it is no measure of its workability or potential.
regards,
Douglas
the Tnuctipun will return
Old 7th December 2003, 12:12 PM   #7
The people who uses 811A, 805 and other tubes that draws grid current often drives them with inverting interstage transformers.
Since the transformers are inverting the grid current and the driver tubes plate current is out of phase, partially cancelling the DC flux in the core. Very clever, but the transformers has to be very well made to work well in inverting mode.
Instead of using servo circuits to get perfect cancellation we could use a tiny airgap that allows some imbalance. I believe itīs benificial for the linearity, by the way. The primary inductance would still be much higher than a regular SE- tranny with a fullsize airgap.
WTB: Single Ended Output Transformers Zedguy Swap Meet 2 2nd August 2009 02:05 AM
Using an output tranny from a stereo for a single-ended amplifier ? bereanbill Tubes / Valves 1 3rd April 2009 03:15 PM
Single-ended input to balanced output, no DC offset LineSource Solid State 16 19th October 2005 09:32 PM
Black Art Single Ended Output Transformers DVDHack Tubes / Valves 2 11th January 2004 04:02 AM
Using PP output transformers for single ended amp SHiFTY Tubes / Valves 4 26th August 2002 07:18 PM
Copyright Đ1999-2017 diyAudio
