Single-Stage Hybrid Cascode Power Amp - diyAudio
Old 15th June 2013, 09:49 AM   #1
jazbo8's Avatar
Question Single-Stage Hybrid Cascode Power Amp
Found an interesting design over at Softone - it's a single-stage cascode amp, since the MOSFET is providing most of the gain, I am curious how it would sound? (I can't breadboard it now, as all my tools are in storage...) Comments and feedback are appreciated.
Original article in Japanese.
It's basically a single-ended version of this design.
Jaz
Old 15th June 2013, 10:19 AM   #2
artosalo's Avatar
Output tube is grounded grid connected and driven by a MOSFET.
Output impedance is high, but reduced a bit due to GNFB.
Old 15th June 2013, 04:10 PM   #3
This trumps the main weakness of any mosfet: variable capacitance squirming back
and forth, from drain to source, as the bias changes. The cathode pins the drain to
a fixed bias, and stops multiplication of drain capacitance by Miller.
Old 15th June 2013, 04:39 PM   #4
hpeter is offline hpeter  Slovakia
hpeter's Avatar
Jaz
thanks for link, got that on my mind how to drive hi mu tubes..
BLOG. XMOS_U8/PCM5102A > LL1544A > 6H1Pi+µfoll > 2A3_SOV/JJ > LL1660 > STAX SR207 _ SR L300 _ SR007 # LL2748 > 394A > LCLC 4H/100µ
Old 15th June 2013, 04:46 PM   #5
hpeter's Avatar
seems this schema makes tubes as serial constant U reg..by resistor divider
mosfets "just" changing current
low damping factor, what basically is preferred with hieff boxes
Old 15th June 2013, 11:32 PM   #6
jazbo8's Avatar
Thanks for the feedback, gents. I will breadboard it once I get my bench set up... the differential push-pull version is interesting as well. I also have a question on the gain calculation, in the write-up, the gain for the cascode stage is just gm x (ra//RL), where gm is the transconductance of the mosfet, ra the plate resistance of the tube and RL the primary impedance of the OPT, and yet he mention the ra should be > 50K even though none of the tube types used has ra anywhere near it, so why make a fuss about it?
Old 16th June 2013, 05:53 AM   #7
hpeter's Avatar
voltage seems changes up to few 10´s, he could implement voltage fb circuit like in tube voltage regulators to have steady drain U.
Old 16th June 2013, 07:18 AM   #8
hpeter's Avatar
not optimal i know
Old 16th June 2013, 06:24 PM   #9
Power tubes in cascode for output section?
Old 16th June 2013, 08:21 PM   #10
jazbo8's Avatar
Originally Posted by Sergey A View Post
So how does it sound? Is it more of FET or triode characteristic?
Jaz
Swing Electroimpex Amp Taiga W-1000A equipped with Hybrid Power Stage Sanken S-40W tiefbassuebertr Solid State 1 16th January 2013 01:39 PM
SSE as Single Stage Power Amp Davec113 Tubelab 4 6th December 2012 08:36 PM
KT88 single stage pp - cascode diff amp Andrewbee Tubes / Valves 1 2nd August 2011 12:53 AM
Hybrid SEPP Cascode TransNova High Zo Amp CLS Solid State 6 30th November 2009 07:58 AM
Single Stage power amp. lumanauw Solid State 10 2nd April 2004 09:03 AM
Copyright ©1999-2017 diyAudio
