Soundstage
Soundstage
Old 13th June 2013, 03:47 PM   #1
mjock3 is offline mjock3  United States
Default Soundstage
What affects the soundstage a preamp produces? The reason I ask is when I hook up my DAC directly to my amp I get a significantly wider soundstage that I do when I put the preamp in between. I am wondering where I could start to look in the preamp to improve on this.
Old 13th June 2013, 04:31 PM   #2
kevinkr's Avatar
Soundstage
Cross-talk between the two channels. Most of this will be caused by capacitive coupling between the channels (wiring, switches, and volume controls), common and relatively high impedance ground connections. Coupling through the power supply at both frequency extremes.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 13th June 2013, 04:48 PM   #3
john dozier is offline john dozier  United States
john dozier's Avatar
And generally the increased distortion of all types caused by additional gain stages and cabling.
Evil looms. Cowboy up. Kill it. Get Paid.
Old 13th June 2013, 05:08 PM   #4
kevinkr's Avatar
Soundstage
Probably would not be a bad idea to give us a lot more detail about the components in your system. It may be that a simple passive attenuator is all that is required here unless you also play LPs.
Consider posting schematics or links to same of your pre-amplifier. Follow copyright requirements for any documents you post.
Old 13th June 2013, 05:32 PM   #5
Many DACs have built in volume controls. Regards
Old 13th June 2013, 05:49 PM   #6
GoatGuy is offline GoatGuy  United States
GoatGuy's Avatar
Interesting theories here ... but what of compression? A remarkable number of preamps - especially based on FETs and triodes, compress the signal audibly. In "live sound" mixing (one of my hobbies), this isn't a bug, but a feature. Indeed... so much so, that most 2012 or later mid-grade mixers have 50% to 100% of their input line preamps outfitted with a variable compression knob. Does remarkable things for vocals. Even the circa 1995 Yamaha 01V (digital mixer) had both compression and expansion in a combo-function that could be engaged on any channel.
Having built a number of FET and triode "Preamps" (I put that in quotes, because its simpler than saying, "sound contouring modules") for a whole bunch of different applications, compression is a very real phenomenon that can be employed (or worked around) at that critical first input stage. Bug, or Feature ... depends on what you're trying to achieve.
I could imagine that subtle compression would make the soundstage seem smaller. Does in live music!
GoatGuy
Old 13th June 2013, 06:45 PM   #7
Yes I am able to control volume in digital domain. Would like to get away from that by using a preamp. Also because I have inefficient speakers I need more gain. The preamp in question (currently) is a Tubes4Hifi Aikido. It is only 15 db gain so not over the top. It appears to be pretty simple circuit and has a decent sound though lacking in clarity and soundstage. I think I know how to improve the clarity aspect. But I have no knowledge base for soundstage.
Here is a link:Dynaco PAS3 rebuild in addition this power supply http://www.tubes4hifi.com/PAS3.htm#regPS
Old 13th June 2013, 07:38 PM   #8
Palustris is offline Palustris  United States
Palustris's Avatar
There is a misunderstanding here: the maximum output from the amplifier is a function of its input sensitivity. If your amplifier reaches clipping, i.e. maximum output, with 500mV input, then applying 501mV input will just drive the amp further into clipping. If you have inefficient speakers you need more wattage output from your amplifier not voltage input from the preamp.
Old 13th June 2013, 09:12 PM   #9
I have 400 watts per channel (Ncore). Wouldn't the DAC cause the same thing?
Old 13th June 2013, 09:30 PM   #10
DF96 is offline DF96  England
Balancing imperfections with imperfections, as claimed in the link, is rarely a good idea except in truly balanced configurations like push-pull or LTP.
SoundstageHide this!Advertise here!
Soundstage Help easymac77 Analogue Source 8 18th July 2010 02:14 PM
visualise soundstage neutron7 Everything Else 0 14th February 2005 07:39 PM
Soundstage- What creates it? Sherman Multi-Way 25 16th July 2004 01:21 PM
Help, what changed soundstage? Newbie Multi-Way 2 25th July 2003 02:16 PM
Aleph 3 - strange soundstage Koy Pass Labs 7 15th November 2001 07:22 AM
