Bootstrapped Cathode Coupled Amplifier
Old 12th June 2013, 10:10 PM   #11
tomchr is offline tomchr  Canada
tomchr's Avatar
Originally Posted by JFace View Post
Is that the quick and easy equation? I've always used:
A = (u * Plate load) / (Plate Load + anode resistance + Cathode resistance*(u + 1))
Yeah. It's the quick and dirty equation. In practice, the gain will be slightly lower than Rload/Rcathode as the gain of the tube isn't anywhere near infinite.
I tend to take an intuitive approach to circuit design. I make a couple of quick back-of-the-envelope calculations to get started and throw it into a simulator for the finer detail. I follow that up with the final optimization in the lab. For most work, the quick & easy equations get you close enough.
~Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Bootstrapped Cathode Coupled AmplifierHide this!Advertise here!
A Direct-Coupled Amplifier with Cathode Follower 6V6 livingdeliberately Tubes / Valves 6 31st March 2011 06:41 PM
Cathode follower amplifier, push-pull, xformer-coupled 00940 Tubes / Valves 3 19th November 2010 01:53 PM
cascode vs asymmetrical cathode coupled oldeurope Tubes / Valves 47 18th April 2008 04:37 PM
TCJ Cathode-Coupled Amplifier seventenths Tubes / Valves 3 18th July 2007 05:05 PM
Help with a cathode coupled pentode driver? Svetlana Tubes / Valves 2 26th July 2006 01:06 PM
