Bucking and boosting a tube power transformer - Page 4 - diyAudio
Old 11th June 2013, 08:38 AM   #31
ranhaber's Avatar
Originally Posted by boywonder View Post
With 227VAC going into a 230V primary tap and no load, I would expect the HT and 5V to be a bit higher........the 6.64V filament winding looks reasonable.
The HT tap is rated at 350V at 350ma.
Ran: Do all of the 5V taps measure 4.97V unloaded?
In the datasheet of the transformer it show that the HT tap in 350ma is 443DC.E.V ~ 313VAC or i don't read the spec right?
No i didn't measued all the tap, only the ones i connected to the board. i thought that if the reading with the cheap meter were the same so will the measurs with the expensive meter. (And because it was 00:30 so i was too tired)
I'll check them later.
Old 11th June 2013, 09:36 PM   #32
ranhaber's Avatar
All taps have 4.97V and 6.64V
Boosting the power of an amp or building my own? Mast0rMason Chip Amps 10 31st May 2013 03:36 PM
FS: TUBE POWER TRANSFORMER DIYspaceW Swap Meet 10 27th December 2012 07:43 AM
Implications of boosting transformer voltage N Brock Power Supplies 3 7th September 2012 09:34 AM
Power transformer for 6883B tube uses? diamondsouled Tubes / Valves 1 14th May 2008 07:52 PM
toroid Transformer as power Transformer for tube tone Tubes / Valves 7 11th February 2003 08:57 AM
Copyright 1999-2017 diyAudio
