Bucking and boosting a tube power transformer
Old 10th June 2013, 08:53 AM   #11
ranhaber is offline ranhaber
ranhaber's Avatar
what about boosting the heater voltage by using double-voltage circuit and tune the correct voltage with resistors?
or just use the 6V and tune the correct voltage with resistors?
Old 10th June 2013, 09:42 AM   #12
Vinylsavor is online now Vinylsavor  Germany
Vinylsavor's Avatar
Hi!
voltage doublers work best in low to medium current power supplies. For a heater supply you would need rather large caps. Doable, but keep in mind that the current load on the transformer secondary doubles when it works into a voltage doubler circuit.
Best regards
Thomas
http://vinylsavor.blogspot.com/
Old 10th June 2013, 10:29 AM   #13
FoMoCo is offline FoMoCo  United States
Originally Posted by Vinylsavor View Post
Hi!
Best regards
Thomas
I second that.
I would not advise that approach, even if it is doable to some degree.
Account Deletion Requested: 1/26/2014
Old 10th June 2013, 10:32 AM   #14
ranhaber's Avatar
What about using a pair of ordinary high-current silicon diodes, that will be added to the heater chain to drop the heater voltage by about 0.7V. Like the picture below.
i mesured 6.1V unloaded. so will it be good for 5V heater rectifier?
Old 10th June 2013, 10:33 AM   #15
Vinylsavor's Avatar
Hi!
Agreed! The heater winding might heat up a lot due to the current spikes.
Better get a proper power transformer for the task
Thomas
Old 10th June 2013, 10:34 AM   #16
Vinylsavor's Avatar
Hi!
Those diodes will dissipate the same amount of heat as properly sized resistors for the task. No big advantage. With resistors you can better fine tune the voltage to the required level.
Thomas
Old 10th June 2013, 10:45 AM   #17
In my opinion:
1) Diodes are better when the load varies a lot. This means a (semi)constant voltage drop. But, as already mentioned, you can't easily tune the voltage.
2) Resistors are better when the load is constant. You can more easily tune the voltage drop and the constant drop of a diode isn't needed. In addition, the resistor helps with inrush current.
In both cases roughly the same power is dissipated. (It's actually slightly less in the diode, but I'll skip the math here. The difference isn't relevant.)
For a tube filament, number two applies. I'd use the resistor if given the choice between resistor and diode.
Old 10th June 2013, 01:36 PM   #18
kevinkr's Avatar
Given the local supply voltage and the 230V primary I would expect the secondary voltages to no more than 5% low under load. I'm wondering about the accuracy of the voltmeter used to make these measurements.
I am not a fan of boost/buck winding connection when secondaries are used to do it for safety reasons. A small 9V - 12V filament transformer configured as an auto-transformer on the primary side of the transformer is a lot safer and IMLE works very well. (Also leaves those filament windings available for possible use.)
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 10th June 2013, 01:54 PM   #19
boywonder is offline boywonder  United States
boywonder's Avatar
Default after a good night's sleep......
Ranhaber: A comment and an idea......
In your configuration in post #10 since you are using two windings in series with the primary you need to have all of the windings in the proper phase. If one (or both) of the LV windings are bucking instead of boosting, your voltages will be lower, or only slightly raised.
Try it with one of the 6.3V windings to start, and convince yourself that you can boost/buck, then add the second winding.
Here is another idea that may be a lot more practical and eliminates the isolation and saturation issues, and may even offer some improvement for a Tubelab SE:
Don't boost anything; use the transformer as-is. This gets you 350-0-350 or so which is more than enough for 300B operation.
Use a 6.3V winding with a dropping resistor for the rectifier. (Experts: Is this practical?)......or diodes using the forward voltage drop?
Use two 5V windings in series for around 9V into the filament regulator. This provides additional voltage headroom into the filament regulator which may be a good thing. The Tubelab SE regulator has minimal regulation with 6.3V input. This higher voltage will burn more heat; you'll need ample heat-sinking.......We'll have to look at the specs for the regulator to verify.
For those following along, here is the schematic:
Schematic
Old 10th June 2013, 01:56 PM   #20
boywonder's Avatar
I'm wondering that too.........perhaps a CAREFUL measurement of the house voltage at the wall...
Bucking and boosting a tube power transformerHide this!Advertise here!
Boosting the power of an amp or building my own? Mast0rMason Chip Amps 10 31st May 2013 03:36 PM
FS: TUBE POWER TRANSFORMER DIYspaceW Swap Meet 10 27th December 2012 07:43 AM
Implications of boosting transformer voltage N Brock Power Supplies 3 7th September 2012 09:34 AM
Power transformer for 6883B tube uses? diamondsouled Tubes / Valves 1 14th May 2008 07:52 PM
toroid Transformer as power Transformer for tube tone Tubes / Valves 7 11th February 2003 08:57 AM
