33A-158M - diyAudio
Old 8th June 2013, 11:03 PM   #1
Matt BH is offline Matt BH  United Kingdom
Default 33A-158M
Does anyone have the datasheet for these? I have acquired some but cannot find much info. I know from the usual Google search that they are similar if not the same as 6N7 but an actual datasheet would be great.
Thanks in advance
Matt.
Old 9th June 2013, 12:33 PM   #2
Vinylsavor's Avatar
Hi!
Not a complete data sheet, but some info:
CV1884 / 33A/158M
Not similar to a 6N7 at all. Different base, different amplification factor, different plate resistance.
Best regards
Thomas
http://vinylsavor.blogspot.com/
Old 9th June 2013, 09:01 PM   #3
Thanks Thomas, I got the 6N7 idea from eBay. Probably the usual thing where the seller just makes stuff up to sell tubes.
Anyway they look useful. I might use them as drivers in a push pull amp or as finals in a small push pull amp.
Cheers Matt.
Jmlab SW-33A repair Jonas83 Subwoofers 3 9th April 2014 08:38 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
