6N1P
6N1P
Old 8th June 2013, 03:59 PM   #1
llan is offline llan
Default 6N1P
I want to use a 6N1P valve as a line input and a concertina phase splitter, having
280 volts on the B side of the HT could any one suggest the resistors for the plate and cathode voltages so as to obtain the least distortion.
llan
Old 8th June 2013, 04:44 PM   #2
LinuksGuru is offline LinuksGuru  Europe
Take a look at improved Williamson Amplifier, it uses DC coupled 6SN7 input and concertina. You can replace 6SN7 with 6N1P.
Old 9th June 2013, 05:42 AM   #3
artosalo is offline artosalo  Finland
artosalo's Avatar
How much drive voltage you need from 6N1P concertina ?
Which output tubes ? 280 V as +Ub is quite low.
Old 9th June 2013, 05:58 AM   #4
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
6N1P
and I thought 6N1P would want it even lower ?
Old 9th June 2013, 06:48 AM   #5
artosalo's Avatar
With higher +Ub the output can be higher as well. Isn't this obvious ?
EDIT: When R2 = 1k8, max. output is some 28 V.
Old 10th June 2013, 01:21 PM   #6
Default 6N1P
Thanks for your input, my line input stage as a 47K on the plate and a 1K on the cathode the other half used as a phase splitter as two 33K resistors one for the
plate and one for the cathode to drive a couple of 6L6 valves, is there any way to improve this concertina phase splitter or do you have to use a better type phase splitter for lower distortion and a better top response, the Radford 25 watt amp used a ECF82 as a phase splitter I believe this was done to improve the high frequency response.
Llan
Old 10th June 2013, 02:09 PM   #7
6N1P
how about using 6n6p/ecc99 instead ?
Originally Posted by llan View Post
....is there any way to improve this concertina phase splitter....
Llan
Old 10th June 2013, 07:34 PM   #8
artosalo's Avatar
...my line input stage as a 47K on the plate and a 1K on the cathode the other half used as a phase splitter as two 33K resistors one for the plate and one for the cathode to drive a couple of 6L6 valves, is there any way to improve this concertina phase splitter or do you have to use a better type phase splitter for lower distortion and a better top response...
Llan
I understand that your 6N1P amplifier stage is direct connected to cathodyne.
If this is correct, this is the reason for high distortion.
To make well designed and well performing amplifier/phase splitter you should use a capacitor between the stages and bias both to optimum.
I already gave you a schematic of such cathodyne.
The frequency response of cathodyne stage is beyond 100 kHz, so should not be a problem.
You told in the first post that the supply voltage is 280 V. What is the supply voltage for the 6L6 output tubes ?
Old 11th June 2013, 03:13 PM   #9
Default 6N1P
Sorry, I made a mistake, I have two amps one both using the concertina phase splitters, the one with the 280 B plus volts uses EL84s as push pull output the other uses two 6L6s in the out put this amp as 365 volts on the plates of the 6L6s and the B plus is 350.
Yes there are both DC coupled, I have seen this being used in other valve amps why is it important to use a coupling cap instead of it being dc coupled how does this lower the distortion.
I take your point about the 6N6P/ECC99 would this be a better valve for this position.
Llan
Old 11th June 2013, 05:15 PM   #10
artosalo's Avatar
...Yes there are both DC coupled, I have seen this being used in other valve amps why is it important to use a coupling cap instead of it being dc coupled how does this lower the distortion....
Llan
When the voltage amplifier stage is operating at minimum distortion point, its anode voltage is, say 150 V for example.
The optimum bias voltage of a concertina at 280 V +Ub is much smaller, say 80...90 V.
If you direct connect this 150 V to concertina, its output voltage is highly limited. On the other hand, if you bias the voltage amplifier so that its anode voltage is 90 V, the result is distorted output signal at the voltage amplifier.
Therefore individual biasing is necessary in most cases.
Direct connection works well with some pentodes as voltage amplifiers because these operate at low anode voltage.
Also 12AX7 is good with direct connection if small driving voltage is required.
There is basically no difference if 6N1P or 6N6P is used as a concertina, because it has full negative feedback that minimizes the differences between used tubes/types.
6N1PHide this!Advertise here!
6N11 = 6N1P ? JoeDJ Tubes / Valves 7 16th May 2011 01:31 AM
6N1P bob56 Tubes / Valves 3 30th December 2010 01:50 AM
Sub 6n6p for 6n1p? toufu Tubes / Valves 3 22nd April 2010 04:43 AM
replace 6N1P with 7308 dsavitsk Tubes / Valves 2 10th July 2007 02:59 AM
6n1p Screen matthew2456 Tubes / Valves 1 22nd January 2007 05:01 PM
