6N1P
6N1P
Old 5th December 2017, 01:37 PM   #11
Tyimo is offline Tyimo  Hungary
Hi Artosalo!
Therefore individual biasing is necessary in most cases.
Could you show me such a circuit (capacitor coupled) with B+ 260Vdc?
greets:
Tyimo
"Replacing any coupling capacitors with a well designed and correctly matched driver or interstage transformer yields an almost shocking improvement in sound..." Peter Qvortrup
Old 5th December 2017, 02:43 PM   #12
artosalo is offline artosalo  Finland
artosalo's Avatar
Here you go.
If the cathode voltage of the phase splitter is above, say 75 V, you can decrease it by increasing the value of R2. Optimum is some 60...70 V.
Last edited by artosalo; 5th December 2017 at 02:58 PM. Reason: Modified schematic
Old 5th December 2017, 02:58 PM   #13
Thanks!
Is this biased to 3mA? Isn't it not too low?
Old 5th December 2017, 02:59 PM   #14
artosalo's Avatar
Notice that I modified the circuit one minute ago.
What output tubes you plan to use ? Fixed or cathode bias ?
EDIT: I was a bit hasty with the simulation. The actual max. output is 30 Vrms with 0.62% THD.
Old 5th December 2017, 04:21 PM   #15
Thanks!
I was interested it only in theory.
If I would use it then it would be the attached schematic.
Old 5th December 2017, 06:30 PM   #16
sser2 is offline sser2  United States
This quote is highly relevant to a phase inverting stage.
Old 6th December 2017, 02:50 AM   #17
Fenris is offline Fenris  United States
Tyimo is right on. That schematic is from Broskie and I've used a modified version of it before with great success: Just what the world needs - another EL84 amp
You could also try replacing the anode resistor with a CCS and/or the cathode resistor with a red or yellow LED.
The amp I'm working on does something similar. It's a PP EL-84 and uses a 6N1P as the driver and phase splitter, but with an order of magnitude lower distortion.
Listen to the music through the stereo, not the stereo through the music.
Old 6th December 2017, 05:56 AM   #18
Hi!
I just wanted to know what would be the ideal bias for the 6N1P in this Tubcad circiut with a lower voltage. say ca. 250-260 B+.
Old 7th December 2017, 02:16 AM   #19
Aim for half of B+. 25-26K for the anode load and the same 340 ohms on the cathode. Or better yet a red LED on the cathode.
Old 7th December 2017, 07:39 AM   #20
Thanks!
What about the concertina stage?
6N1PHide this!Advertise here!
6N11 = 6N1P ? JoeDJ Tubes / Valves 7 16th May 2011 01:31 AM
6N1P bob56 Tubes / Valves 3 30th December 2010 01:50 AM
Sub 6n6p for 6n1p? toufu Tubes / Valves 3 22nd April 2010 04:43 AM
replace 6N1P with 7308 dsavitsk Tubes / Valves 2 10th July 2007 02:59 AM
6n1p Screen matthew2456 Tubes / Valves 1 22nd January 2007 05:01 PM
